10-05-2008
The new high-tech lines, like the Spectra or Dyneema based lines have about as much stretch as wire and are much lighter. In many cases going to an all line halyard will save you money in the long run, as you can end-for-end the halyard, which you can't do with a wire halyard. You do have to inspect the masthead sheave and exit slot for any damage and to make sure the sheaves are compatible with all rope halyards. Also, no meat hooks on all line halyards.
Originally Posted by sasfish
As others have said this is an old style of redusing strech. Get some sectra and replace the shim ( If needed) and you'll be right. The plus to all line is no fish hooks.
