Old 10-05-2008
CDC2's Avatar
CDC2 is on a distinguished road
Question Winterizing Yanmar & Velvet Drive
This will be the first year I have winterized my boat and I have too simple things I haven't figured out.
First, how do I drain the fresh water coolant out of the engine (Yanmar 4JH2E) to replace it. I can't find anything in the manuel about which valve to use as a drain.
Second, do I simply pump the ATF out of the Velvet Drive dipstick or do I have to drain it some other way?
TIA
Old 10-05-2008
k1vsk will become famous soon enough
Look at the Yanmarhelp.com site for specific directions and pictures.
There are four drains, two on either side. Look for the petcocks which usually have clear plastic hoses attached to drain into the engine sump. You will also need to drain the water heater core and associated hoses and avoid air entrainment when refilling.
Old 10-05-2008
CDC2's Avatar
Site under Construction
I have tried that site before and it is underconstruction. Do you have another URL?
TIA
Old 10-06-2008
Brezzin's Avatar
Brezzin is on a distinguished road
Send a message via AIM to Brezzin
Try this one
Yanmar Marine Engine Help
It's pretty limited and probably won't answer your questions
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Old 10-07-2008
rperret's Avatar
rperret is on a distinguished road
buy a manual - its worth the $40.
The beat goes on, the beat goes on...
The grocery stores the super mart, uh huh
Little girls still break their hearts, uh huh
And men still keep on marching off to war
Electrically they keep a baseball score
Winterizing Yanmar 27 offline2004 Gear & Maintenance 7 02-17-2006 09:09 AM
Water Drive Mark Matthews Cruising Articles 0 12-05-1999 07:00 PM
