Old 10-05-2008
montenido's Avatar
montenido is on a distinguished road
Adding a Deck Hatch
Hi all. I am getting ready to add another deck hatch to my Cat 30. Being an older model it has only one small opening hatch in the cabin and the larger one forward at the v-berth. Some newer models docked near mine have up to two additional small opening hatches (10" x 10") in the cabin. Well, I have bought one and I am going to install it over the head. My question is this: Can I safely install it with the hinge-side facing aft? With it opening toward the front there would be a significant increase in airflow, especially when docked or anchored. I realize that it might be vulnerable while under way, so I would probably close it.
Any thoughts or prior experience with this issue?
Thanks, montenido
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 10-05-2008
Yes, you can install it... but remember to remove the core material for at least 1/2-3/4" around the edge of the hatch cutout and to drill the fastener holes oversized and pot them with thickened epoxy.
As for whether it should open aft, with the hinges forward, or open forward with the hinges aft... it depends... If it was aft-opening, it would tend to act to pull air from the boat, and that is probably better than bringing air into the boat, considering that it is located in the head compartment. Also, that would be safer if the deck gets swept by green water.
Ask yourself, do you really want air coming through the hatch and spreading whatever odors may be lingering in the head compartment around the rest of the boat???
Old 10-05-2008
montenido's Avatar
Very good point SD, I don't need to "savor" the head odors.
montenido
Channel Islands, CA
Mark Twain
Old 10-05-2008
LOL... thought that might be important...
montenido
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
