Old 10-05-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
Building a small plywood work boat
Well this isnt too sailing related, except for the fact that it would be for me to shuttle supplies to my boat wile this in water rebuild goes on.
My skiff is done for and and ive had it with the jon boat ive got. So its time to either buy or build a new boat. I cant afford to buy a boat, so im building from plywood and epoxy. Since i know my boat building skills are crappy, im going for a simple little barge to use. I figure 14' long and 5' wide with 30'' high sides. It will be a work boat plain and simple. I can keep my generator aboard it and probley put a tool box on it.
Now i need some tips on how to go about doing this. I figure ill make ribs to go inside out of 3/4'' plywood and then skin it with door skin and fibreglass. Ill make a piece of plywood for the transom by glueing 2 sheets of 3/4'' together. It will have to be self propelled by my 3hp Johnson. I need some tips and ideas here.
1972 Pearson 36 S.V. Distant Star
Old 10-06-2008
Always learning...
jwoytek is on a distinguished road
So I know a couple of folks who have built these fun little boats from plywood, screws and glue called the "PD Racer". I don't have enough posts for link posting yet (yes, I know, visit the song thread), but search for "pdracer" and you'll find a number of sites with plans and construction details.
It isn't exactly what you're after, but maybe it will help on your basic design and construction concepts. Note that these guys usually don't glass anything--they seal the screw holes and go for broke. Of course, they usually aren't out in a ton of water with expensive tools and/or equipment on board.
jonathan
Old 10-06-2008
I wouldn't use plywood for the "ribs".. plywood doesn't take screws well into the edges. Use some decent 1x2, assemble the frames with plywood gussets and skin the result as planned.
Glen-L offers a line of plans that might suit your needs. Even if you don't want to spend on plans and patterns, there will be some ideas for you here.
Check out their site:
Boat plans, boat building kits for amateur boat builders
1984 Fast/Nicholson 345
Old 10-06-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
DS
I dont know mate
What are you planning on using it for other then working on your boat?
If it were me I'd just find somthing like this and strap on a trolling bracket and put your outboard and be done with it...unless you really just want another project.
Give it away for free when your done.
1980 bayliner with trailer
Old 10-06-2008
'72 Pearson 36
If i wanted to i could just stick the sailmaster on the back of my old Starcraft ski boat, but id rather have a decent little work barge. I figure i can get it build this week. Ive got most of the door skin already and some of the plywood to build it.
Old 10-06-2008
Don't use plywood as Faster has said... solid wood framing would be better.
Don't forget to round the edges and fillet the joints so that the glass will layup nicely. Door skin may be a bit weak for the skin on a boat the size of the one you're describing, and 1/4" ply might be a better skin material.
Old 10-06-2008
sailortjk1's Avatar
Nice little 14' skiff can be found in Faster's link.
Looks to be exactly what you are looking for.
Courtney is My Hero
Old 10-06-2008
ckgreenman's Avatar
AFOC Stinkus Potus
ckgreenman will become famous soon enough
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
Plywood is probably ok for a simple skiff but I'm not sure how much weight you could carry in a plywood boat.
Have a loot at look at Devlin Designing Boat Builders - Design Catalog
Samuel Devlin also has a book about Stitch and Glue boat building.
On the other hand, as Stillraining mentioned, it might just be better to find a cheap boat on ebay or something and just rug up a trolling motor ot small outboard or something. Rip out what you don't need then just sell/give it away when you're done.
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
Old 10-06-2008
Banshi's Avatar
Banshi is on a distinguished road
Sounds like you need to get a copy of this book "Delvin's Boat Building" It shows how to built boats using the Stitch and glue method. Very simple and straight forward method for building boats using plywood reinforced with fiberglass.
1976 Chrysler 22 "CinJam"
Old 10-06-2008
Banshi's Avatar
OOps I was beat to the punch, should have read that last post first
Building Our Sailboat Michelle Potter Buying a Boat Articles 0 04-22-2004 08:00 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
Replacing Our Boat Sue & Larry Buying a Boat Articles 0 07-31-1999 08:00 PM
