10-09-2008
Originally Posted by poopdeckpappy
Question, if you used a adhesive/sealant with a 1000psi break point on stanchions or chain plates that where also though bolted, why would the elasticity be a factor
Let's further qualify that by saying a properly designed and fabricated stanchion base or chainplate, through-bolted to a properly reinforced section of deck or hull, with a proper backing plate...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , from the Chesapeake to Newfoundland
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , a new voice for ocean conservation
