Blogs
User Name
Old 10-06-2008
newportknots newportknots is offline
newportknots is on a distinguished road
Rail Mounted Propane?
Hey there,
My boat is currently set up with a CNG stove and I'd like to make the switch over to propane.
I don't have a free spot for a vented locker and was wondering if anyone had experience mounting tanks outside. I've seen setups with a couple of 6lb tanks on the stern rail - is this considered ABYC compliant?
W.D. Schock New York 36
Boston
Old 10-06-2008
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
While it is probably fairly safe to rail mount propane tanks, provided they're not over the cockpit and the propane will drain overboard, I doubt it is ABYC compliant.
Be aware that you'll have to replace the burners if switching from CNG to propane.
If you're new to the Sailnet Forums... please read this POST.
Old 10-06-2008
montenido's Avatar
montenido montenido is offline
montenido is on a distinguished road
Hi, I also have CNG and I'm curious as to why you are going to switch? My CNG cylinder is in the stern lazarette and so far I have no complaints.
Thanks, montenido
1981 Catalina 30, "Sundance"
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Sponsored Ad
Old 10-06-2008
CNG has serious availability problems, and if you're going long-term cruising outside of the USA, it is often impossible to get. Propane is pretty widely available, and where it isn't, you can often get GAZ or butane, either of which will work in a propane stove, but not in a CNG one.
Old 10-06-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
I don't think ABYC would object to something like this:
Old 10-06-2008
bestfriend's Avatar
bestfriend bestfriend is offline
Hitchin' a ride
bestfriend is a jewel in the roughbestfriend is a jewel in the roughbestfriend is a jewel in the rough
CD......... Post For You!!!!!
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 10-06-2008
Faster Faster is online now
Moderator
Faster has a spectacular aura aboutFaster has a spectacular aura about
We ran our former boat with this setup (below) for over a decade without problems, and there's no issue whatever with propane accumulation anywhere near the tanks! We bent the rings (seen at the bottom of the tanks) from 1/2" SS tubing, they were clamped to the vertical stanchion of the stern pulpit.
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
Old 10-06-2008
If the tanks are going to be exposed to a lot of sea water, it would probably be best if you used COMPOSITE tanks. The fiberglass tanks won't rust or corrode, like aluminum or steel tanks.
Old 10-06-2008
Moderator
Actually we had surprisingly little problem with our tanks rusting or corroding.. in fact these exposed tanks fared better than those in our current boat's traditional "propane locker" - probably due to frequent fresh water rinses (it rains a bit here) and the ability to quickly dry off.
Old 10-06-2008
Moderator
I wonder about UV, though.
Although I'd worry more about the propane lines and UV. It would be good to sleeve them with some material (hollow dacron webbing?)
Faster's tanks look better than the ones we have for our home BBQ...
vB code is On
Something New to Worry About - Propane Hazard jparks Gear & Maintenance 8 06-18-2008 06:52 AM
Pearson 36-2 rub rail damage Paysay Gear & Maintenance 3 07-12-2007 08:56 PM
Aluminum toe rail shantijwk Gear & Maintenance 4 05-15-2007 12:49 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 09:00 PM
Page generated in 1.3224 seconds (84.99% PHP - 15.01% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
