filling a small gap - SailNet Community
Blogs
Old 10-07-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
filling a small gap
There is a small gap, about a 1/4", between two stringers in my bilge. If I were to get some water there it would be very hard to get it out.
I'm thinking of pouring epoxy in there. I know there are no wires or limber holes to worry about.
What sort of epoxy or other stuff would flow easily into this gap to fill it and seal it permanently?
Old 10-07-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
West System epoxy would work, first paint in some of the straight mix to wet the area and then add filler to the mix and squeeze in. It stays runny for a long time before hardening and can creep into lots of corners. The filler will increase strength and reduce the amount of epoxy you need.
Jonathan-Livingston
Old 10-07-2008
Can't paint in, too narrow & deep.
Old 10-07-2008
hellosailor's Avatar
xort, some of the "gitrot" type pentrating epoxies would be perfect for that. They're designed to be thin and suck into cracks, and into the wood itself. They won't add the strength of conventional epoxies--but they'll do a better job of creeping in and sealing what you've got. I'd start with a smallish pour, just in case that crack is open on the bottom and they can run away through it.
You're not going to be plugging the only air space that lets those stringers breath and dry out, are you?
Old 10-07-2008
Fiberglass encapsulated, so no wood to seal or penetrate.
Old 10-07-2008
Probably will still fill, bond, and seal the way you want it to. I'm sure the various makers could tell you for certain.
Filling small holes. ceol Gear & Maintenance 10 01-13-2008 10:03 AM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 09:00 PM
the perfect 20'' cruising boat? jbarros Boat Review and Purchase Forum 14 04-18-2004 07:45 PM
Drilling and Filling Holes in Your Boat Sue & Larry Gear and Maintenance Articles 0 03-11-2003 08:00 PM
Gender Gap or Gender Mirror? John Rousmaniere Her Sailnet Articles 0 04-11-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
