cracks under deck stepped mast - SailNet Community
post #1 of 2 Old 08-13-2002 Thread Starter
Hi We have a 23ft columbia with a problem. We have developed cracks under the deck stepped mast. Does anyone have any advice on how to deal with this problem
misang is offline
post #2 of 2 Old 08-13-2002
Does water pool at the base of the mast? If so I''d check the compression post to make sure that you do not have a problem with it settling etc. If the problem is with the CP you''ll need to fix that before tackling hte deck repair. It is probably what is allowing the deck to flex under the mast causing the cracks.
ikent is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 12:06 PM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 08:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 09:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
