Blogs
User Name
Old 10-08-2008
ozsailer ozsailer is offline
ozsailer is on a distinguished road
Rebedding staunchions
Hello Everyone.
Well I finally got around to another chore and decided to rebed the staunchions and tighten all the bolts. Trouble started when I went to undo a number of the small bolts holding the base plate to deck and found they were just turning on themselves. When I finally got the bolts out (they are only 25mm long 6mm in diameter) it appeared they had only been threaded into the fibrglass and wiht no other fixing. Is this normal.
How do I fix the problem. I was considering drilling our a 1/2 inch hole, filling it with epoxy, wait till its cured then drill to take a 6mm thread and tap the hole, refit the bolt and refit the staunchion. I have not done this before so any suggestions would be greatfully recieved.
Greg and Sue
Lake Macquarie
Land Down under
Old 10-08-2008
dvideohd dvideohd is offline
dvideohd is on a distinguished road
Read....
Don Casey's book.... "This Old Boat"... or one of his other related books... Great HOW TOs.... If you had hit that thing - when it was needed - you could easily have went overboard... scary thought
--jerry
Old 10-08-2008
floatsome floatsome is offline
floatsome is on a distinguished road
I would consider doing the oversize epoxy and redrill, but then through-bolt with a metal backing plate on the under side, not screw into the epoxy.
Sponsored Ad
Old 10-08-2008
trantor12020's Avatar
trantor12020 trantor12020 is offline
trantor12020 is on a distinguished road
do you have access to under the stanchion? if yes, try getting a longer bolt and tighten with backing washers and nuts. otherwise is there embeded metal plate? if yes, try re-taping it next larger size and get new sets of bolts.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 10-08-2008
NOLAsailing's Avatar
NOLAsailing NOLAsailing is offline
NOLAsailing is on a distinguished road
Hi Greg and Sue - you have to right idea. Also, I think all stanchions should have backing plates.
Although I'm sure you know this, be sure to use a quality sealant when you rebed the stanchions. I recommend 3M 101.
-Jason
Rambunctious, J30 #280
vB code is On
Rebedding in the rain? scove Gear & Maintenance 41 10-31-2008 11:39 AM
Rebedding deadlight - spacer? WinterRiver Gear & Maintenance 3 09-19-2008 09:39 AM
rebedding stanchions adamtroyg Gear & Maintenance 25 06-10-2008 02:20 AM
Rebedding Sail tracks Seekswind O'Day 11 05-09-2007 08:31 PM
Page generated in 0.3291 seconds (48.64% PHP - 51.36% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
