10-08-2008
If you are using the roll and tip method then yes, you need to sand between topcoats. Also, you really should have two coats of primer.
Wait at least 16 hours between coats. Also, throw the recommendation for solvent out the window - thin it as much as you need to to get the right flow. Under some conditions, that will exceed the recommended max of 1/3.
-Jason
