10-09-2008
Ticon 30
I purchased a Evercote Gelcote repair kit. Which was a tube of clear gelcote, hardner and some color tubes.
I fixed about 8 or 10 chips, some about the size of a dime.
All turned out ok, some you cannot see unless you knew where they were and looked very close, others are a little more apparent, but then other than trying to follow instructions, I didn't know what I was doing.
The hardest part was matching the color, white is not white. The smallest amount of color made a huge difference.
I cleaned the areas with acetone before I started, sealed with wax paper to cure and sanded as per instructions. Last sanding was wet with 2000 grit.
Had I paid to have them professionaly done, I am sure they would have been perfect. Then again I have a 33 year old boat not a new one
