10-09-2008
Balmar recommends you use at least AWG4 wire for up to a 15ft run. Note that this is the total run, i.e., from the alternator to the battery and back.
ABYC also says a fuse is a good idea. It should be located near the battery, not near the alternator. Size the fuse for at least 140% of the alternator capacity (or about 80A in the case of a 55A alternator).
Here's what Balmar says:
Quote
Note: Fusing is designed to protect the boat and its wiring from the constant potential energy stored in the battery, rather than output from the alternator. Fusing should always be installed at the end of a wire or cable run closest to the battery. DO NOT place fusing for the alternator’s output cable at the alternator end of the cable run!
We find that a circuit protection device sized at approximately 140% of your alternator’s rated amperage is typically suitable for the circuit being protected. For more info about circuit fusing, see http://www.bluesea.com/circuit.htm.
Unquote
Bill
