Can I get some good epoxy from Lowe's? - Page 2 - SailNet Community
post #11 of 20 Old 10-09-2008
NOLAsailing's Avatar
No - the epoxies Lowes sells are just general purpose epoxies. You want a product with considerably higher strength. Use West System, MAS or another brand suitable for semi-structural marine applications. Jamestown Distributors often have good deals on epoxy; in fact, they have a sale now.
-Jason
NOLAsailing is offline
post #12 of 20 Old 10-09-2008
chucklesR's Avatar
Not all epoxy is created equally.
If you can't get West or MAS locally you should order it online. They are formulated to work well in the marine environment - but yes, you can use the Lowes variety - just don't expect the same results and consistency.
Applying it is different based on the consistency of the epoxy. Thickened epoxy (with filler) can be troweled on and shaped with plastic applicators (like a putty knife), whereas to coat a large surface with thinned liquid epoxy you want a wider flexible applicator or even a small diameter roller. I typically use a roller to apply and a applicator to squeeze off excess.
For what you are doing, I would not use Lowes stuff. I would never use a garden variety house hold formulated epoxy to saturate fiberglass cloth on a boat, just because. You put a lot of hours into a boat, I want it to last for lots of years.
To restore an older boat it's best to use a CPES (Smith's preferred) to soak into the old wood and seal it totally, then use a quality epoxy for your patching and glue ups including thickened for fillets etc..
There's a lot of info available online, I invite you to google it.
chucklesR is offline
post #13 of 20 Old 10-09-2008
Mud Hen #69, Mad Hatter
Delirious's Avatar
Our Lowes has West Systems. I was impressed (We're 200 miles from the ocean).
Charlie P. Mud Hen 17 #69 Mad Hatter
To travel hopefully is a better thing than to arrive - R.L. Stevenson
I suspect that, if you should go to the end of the world, you would find somebody there going farther . . . - H.D. Thoreau
Delirious is offline
post #14 of 20 Old 10-09-2008
Handsome devil
Stillraining's Avatar
Id did just that Chuck..
CPES™-Wood based epoxy products to repair and resist wood rot.
Great link to there site ..Thank you
Stillraining is offline
post #15 of 20 Old 10-09-2008
Tartan 27' owner
CalebD's Avatar
Perit,
The West System webpage has their entire users manual online if you want to know what other materials they recommend you have for using their epoxy (Acetone, fillers etc etc). I invite you to explore it: WEST SYSTEM Epoxy
You might also be wanting to get some gel coat for those hairline cracks around the stanchion bases.
Good luck with your project.
Everybody has one:
CalebD is offline
post #16 of 20 Old 10-09-2008
Anything-Sailing Founder
ckgreenman's Avatar
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
At the risk of going a little off topic, has anyone used this?
JGreer.com - Epoxy Resin, Urethane Foam, Silicone Mold Making Rubber, Carbon Fiber
According to the website it's supposed to be good for marine use.
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
ckgreenman is offline
post #17 of 20 Old 10-09-2008
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
I cant say if it will or not. I can say that i wouldn't use it for that. I would try to find a local vender for West Systems, or some other epoxy used for boat building.
1972 Pearson 36 S.V. Distant Star
SVDistantStar is offline
post #18 of 20 Old 10-09-2008 Thread Starter
Montgomery 17
Perithead's Avatar
Caleb- Thanks for reminding me about the gelcoat for the cracks. This question may be dumb but it seem logical.
If I am correct doesnt gelcoat go ever the paint to protect the paint? If so, shy should I repair the hairline cracks *with gelcoat* before I paint?
Small is beautiful, simple, cheap, and easy......
Sailing Videos, Woodworking Videos and More!
Perithead is offline
post #19 of 20 Old 10-14-2008
Perithead-
Gelcoat never goes over anything but raw laminate... you can't gelcoat over paint. If you're going to be painting, repair the cracks by filling them with thickened epoxy... then sand fair and paint.
sailingdog is offline
post #20 of 20 Old 10-17-2008
Casting off May 2009
lassrl's Avatar
I've had excellent results with Raka epoxy... raka.com
lassrl
s/v Joie de Vivre
1976 Whitby 42
lassrl is offline
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 02:11 PM
8 Days on the Road - A Wombats Tail. tdw General Discussion (sailing related) 63 04-23-2008 06:04 PM
Keel Fairing BarryL Gear & Maintenance 34 03-21-2008 11:15 AM
Epoxy on teak? ikent Gear & Maintenance 13 12-03-2007 01:37 AM
Sealing Deck Hardware, and Epoxy over Teak 1970Columbia34 Gear & Maintenance 3 08-24-2006 04:34 PM
