Old 10-09-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
What can i do for these windows on the boat?
This is a 2 part question.
First is what can i do to make these windows look a little better? They really do look like crap. Im not shy of replacing the plexi, and kinda plan to soon.
The second part is, what can i do to seal them? They leak like hell. I sealed them with 5200 right after i got the boat, but they have started leaking again. Yea, i know 5200 isn't right for this now, i didn't know that then.
You can see ive got tape over the top of them, that works for now.
1972 Pearson 36 S.V. Distant Star
Old 10-09-2008
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
This may be helpful:
J/30 Rambunctious - Portlight Replacement
-Jason
Old 10-10-2008
jarcher's Avatar
jarcher is on a distinguished road
You might also find this article interesting:
http://www.sailnet.com/forums/gear-m...ted-ports.html
You already have surface mounted deadlights. How old is the boat? That article discusses converting the frame style to surface mount. It describes how to mount the new surface mount, so it would tell you how to remove and remount your lights.
I have also seen new windows that open and have screens. They come ion a variety of shapes and sizes. Maybe you can find one to fit your boat, assuming you want some that can open.
Old 10-10-2008
tommays's Avatar
The shape does lend it self to finding a window frame extrusion that could be miter cut to form a nice looking cover that could also be sealed
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-10-2008
Buying custom made framed deadlights is the best but priciest way to go.. barring that we have had good success surface mounting plexi with Dow Corning 795.
Hopefully, since your 5200 "sealed" ports leak, they will come off without too much trouble. If you can get one off in one piece take it to a supplier, they can generally cut a couple of copies at a reasonable rate. Use the original as a template to drill the holes and make the holes oversize so that you don't stress the plexi as it expands and contracts. Also avoid overtightening - you shouldn't have dimples in the window at the screws.
These were done this way - a couple of seasons ago and with careful masking and application it looks pretty good:
1984 Fast/Nicholson 345
Old 10-14-2008
A lot of modern boats and older boats being retrofitted don't have frames on the deadlights. They are often replaced with slightly oversized lexan or plexi ports that are through-bolted to the cabintop and bedded in butyl tape.
The trick of doing this is to drill the fastener holes in the plexi or lexan slightly oversized and chamfer/countersink both sides slightly. If you don't counter sink the holes, they will often become the starting point for a stress crack. Then the screws are through-bolted, and butyl tape is used to weatherproof the seal between the glazing and the hull. Paint the outer 1" of the inner surface of the glazing material black so that it hides the butyl tape and such.
Old 10-14-2008
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
The biggest problem you're going to have will be removing the 5200 from the boat. It will fall off the plex, but may remove pieces of the gelcoat getting it off the deck. I would look into 5200 remover, and hope it works.
John USYacht 27 "Cora Lee"
Old 10-14-2008
the debond stuff works relatively well
Old 10-15-2008
'72 Pearson 36
Yea, ive got some butyl tape(nice wood colour). This project kinda got pushed back again for the bulkhead, but i may tackle it tomorrow just to have one less project.
Old 10-15-2008
Be sure to post the "after" picture!
-Jason
Modern Hull forms and Motion Comfort Jeff_H Sailboat Design and Construction 34 04-13-2012 01:41 PM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
