butyl tape - Page 2 - SailNet Community
post #11 of 54 Old 10-10-2008
Maine Sail's Avatar
Originally Posted by artbyjody View Post
Maine, I actually do purchase the stuff through local hardware stores here. Its usually in the screen door sections.
That's cool! None of the hardware stores or home centers around here carry it. I've searched high and low!!
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 54 Old 10-15-2008
Irrationally Exuberant
I got curious after Main Sail's earlier piece on butyl tape, so I got some from the online RV place and used it when rebedding locker hinges. Impressively sticky stuff.
Considering that it seems to stay sticky for a very long time--I think MS showed something that had remained pliable and sticky for over a decade?--and seems easier to work with than a caulk gun full of Sikaflex, I'd like know what its limitations are, if any. Is butyl tape suitable for all above-waterline hardware rebedding jobs? Say for stanchions, clutches, etc?
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #13 of 54 Old 10-15-2008
Maine Sail's Avatar
I've used it on every type of mechanically fastened devices that you can think of and it works great.
Limitations include feathering a joint and smoothing over the bead. I can't think of any use on deck where I would not use it. As i said 80% of my boat has yet to need re-bedding. My genny tracks for example were done at the factory with butyl nearly 30 years ago and they are still bone dry with not even one drip..
______
post #14 of 54 Old 10-15-2008
OK then, MS, I'm going for it. Butyl tape it is. Thanks.
Tom K
2000 Beneteau 331
arf145 is offline
post #15 of 54 Old 10-15-2008
Actually, most of the hardware stores DO carry butyl tape just not where you might think it is. Look for a 3-6' long roll, 1-2" wide, in the PLUMBING section or the ELECTRICAL section. I've bought 3M's prime quality "butyl self vulcanizing tape" in Home Depot, right next to the other 3M electrical tapes, it is used to waterproof cable and antenna splices. These tend to harden up over time, not rock hard but layers fuse. Regular butyl "caulking" tape will stay gummier longer.
Sometimes they stock clear silicone tape--which is pretty much the same product, doesn't quite self-fuse as permanently but can be used as a gasket material just as well. Sold in the plumbing sections (along with butyl) as a hose/pipe leak patch material, too.
I'm assuming the tape is going to be laid down flat as a gasket under the hinge panel--not stuffed in the screwhole. Either of these should work as a gasket material, without needing to buy a huge roll from a special place.
hellosailor is offline
post #16 of 54 Old 10-15-2008
Maine Sail's Avatar
I have both self vulcanizing tape and glazing quality butyl ribbon or flat tape sitting in my shop. They are NOT the same product!!!!!!!! I would never even consider using the self vulcanizing tape over the glazing grade butyl.
The stuff I use is very, very, very gooey and sticky and comes stuck between waxed paper as it can not go onto a tape roll or it will be destroyed trying to un-roll it. There are a few grades of things called butyl but self vulcanizing tape IMHO is not one I'd choose for re-bedding deck hardware.
Perhaps in some parts of the country you can find butyl glazing tape in home centers and hardware sotres but not here. RV stores are the only places I've seen the flat version in colors like gray and off white. Again, I would NOT suggest using black if it can be avoided. I used black on my port lights but only because I could not find a source in the diameter needed in gray or white..
Black Round Butyl Tape:
Keeping the black off the gelcoat:
As you can see I used 3M 101 polysulfide to seal the trim ring to the exterior and the butyl to seal the port to the cabin. This kept the black butyl off the gelcoat..
______
post #17 of 54 Old 10-15-2008
A lot of 'better' junk yards, window companies, and windsheild installers carry the black butyl tape, the window places, and steel siding companies often carry the grey or white variety.
I've picked up the black butyl by asking a windsheild installer who was working in the parking lot, gave him $6 for two rolls, don't know if it was a good or bad price, but we were both happy with the transaction so it wasvalue for value.
Ken
merc2dogs is offline
post #18 of 54 Old 10-15-2008
The stuff I got from the RV supply link Maine Sail provided last time is like very sticky putty in a strip--can be molded to itself just by rolling it between your fingers. It's 3/4" wide and maybe .1 inches thick. I'm planning on using it as my surface "gasket" material and around screw heads and in the deck screw hole countersink. Overall, I like the gray color--it blends in with metal amd looks OK where it shows against the white gelcoat. And you can sort of cut it with a plastic blade to trim after it oozes.
Tom K
2000 Beneteau 331
arf145 is offline
post #19 of 54 Old 10-15-2008
Freesail99's Avatar
When working with the butyl tape, leave the paper backing on, for as long as you can. That will aid you in getting the same thickness over all.
S/V Scheherazade
Freesail99 is offline
post #20 of 54 Old 10-16-2008
Valiente's Avatar
I used this to rebed a 35 year old stern quarter extrusion. It's great stuff. I associate it with automotive window installers.
There are crannies on my boat where a little "overflow" is still malleable and "new smelling"...from 1973.
Valiente is offline
Window gasket sealant.. groundhog Gear & Maintenance 39 07-11-2014 03:27 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 12:33 PM
Paininting non-skid... marinesniper Gear & Maintenance 36 01-29-2008 01:10 AM
Stripping tape removal KenKapt Gear & Maintenance 1 03-12-2004 10:36 AM
