butyl tape - Page 3 - SailNet Community
post #21 of 54 Old 10-16-2008
Wayne25's Avatar
You can also purchase it at any heating and air conditioning (HVAC) supply store. We use it to seal high pressure duct flanges for an air tight joint. Grey in color.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #22 of 54 Old 11-04-2008
Maine Sail's Avatar
Here's why I like butyl tape
This is a cut-a-way photo i made of a section of deck that I first potted with epoxy then countersunk. I then wrapped butyl tape around the bolt head, tightened it down and left it there for a while. I then loosened the bolt and began pushing up from the bottom. There is no movement on a boat, with a mechanically fastened deck fitting, that will even come close to that amount of flex and stress on a sealant.
Remember this stuff has very low adhesive properties, unlike 5200, 4200 or any other caulk tube type sealant, and cleans up quite easily with paint thinner. Adhesion is not necessarily needed flexibility is! This stuff will out stretch and out flex any caulk tube sealant you can buy in a marine store..
Of course you must always bevel or countersink the deck side so you can fit more sealant in the gap. The more sealant the more allowable flex. If you look close you can see the beveled edge.
Yes I finally got sick of trying to describe the process of potting holes and countersinking so I took some pictures.
Stretch!
______
-Maine Sail / CS-36T
Maine Sail is offline
post #23 of 54 Old 11-04-2008
Maine Sail-
Nice photo... very illustrative of the properties of butyl sealant. Glass shops usually carry it btw... but usually only in the black.
sailingdog is offline
post #24 of 54 Old 11-04-2008 Thread Starter
Arf!
pegasus1457's Avatar
A source for the grey butyl tape
I looked all over Long Island, calling a bunch of RV stores, and finally gave up. I ordered mine from The Sportsman's Guide (an amazon.com seller) for less than $10, shipping included.
Fluctuat nec mergitur
pegasus1457 is offline
post #25 of 54 Old 11-05-2008
xsboats's Avatar
I use butyl tape while vacuum bagging. I get it from a roofing supply store. It is used on standing seam metal roofing to seal the seam between sheets. Much cheaper than the specialty vendors of bagging supplies.
xsboats is offline
post #26 of 54 Old 03-12-2009
Butyl tape and visqueen beats tarps and tape for staying dry
We are currently living on a boat with all portlights and one hatch removed. Replacing them is taking longer than expected. Meanwhile, we've had sleet, snow, rainstorms, and temperatures in the 20's.
We are snug and dry, thanks to butyl tape and visqueen plastic.
Here's what we did: We cut a piece of plastic to fit over each opening. We formed a long skinny "snake" of butyl and put it around the perimeter of the plastic, then stuck it on. It's quick to put on and take off (we use a dull razor blade to get it started), so we can put it on at night and take it off while we're working. Unlike tape, it doesn't leave residue and we just keep using the same piece over and over.
This would work for just about any large opening or deck repair.
For small holes, just make a ball of butyl and stick it over the hole.
The only downside to this solution is that when you have hail, it's like living in a large, noisy drum! But it holds up just fine.
s/v Flutterby, Freedom 33
- limericks, essays, and photos by Meps 'n' Barry
- recipes for cooks at sea and on land
mepsnbarry is offline
post #27 of 54 Old 03-12-2009
Wayne25's Avatar
I'll be re-bedding my bow pulpit soon and I have a question on the application of the butyl tape. Obviously it goes around the bolts as per Maine Sail's instructions.
But would you also cover the entire bottom of the plate base with strips of it? I don't see why this would be needed if the bolt holes are sealed with it. Your thoughts..
Wayne
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #28 of 54 Old 03-12-2009
Maine Sail's Avatar
Yes
Yes I cover the entire base of the fitting then tighten it down. It's best to wait for a hot day and the butyl will compress easier.. The problem with us NE boaters is that water can get under a fitting and expand and yuo don't want that so it's best to seal the entire base. Get the thin flat butyl tape. I think mine is 1/16" thick if I am not mistaken.
______
post #29 of 54 Old 03-13-2009
Wayne25's Avatar
Thanks Maine Sail. My tape is about the same. About 1/2" wide and 1/8" thick, gray. I can heat the surface and SS with a heat lamp before I pull everything tight with the bolts. I bed my topside teak hand rails last year and still had some squeeze out the joint during the summer. Easy to remove.
Wayne
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #30 of 54 Old 03-13-2009
Irrationally Exuberant
I think the butyl I have is more like 1/8". I'd love it if it was 1/16" as half of it squeezes out--but at least at that point you can be pretty sure you've got a great seal there.
A couple of things about butyl I've found lately:
* When working on an overhead bolt that hangs straight down, a dot of butyl on a washer will hold it there temporarily while you are trying to get that nut on there.
* Mineral spirits gets it off your fingers and other surfaces if necessary. This is especially handy when your fingers have reached critical mass of stickiness, turning you into spider man.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
Window gasket sealant.. groundhog Gear & Maintenance 39 07-11-2014 03:27 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 12:33 PM
Paininting non-skid... marinesniper Gear & Maintenance 36 01-29-2008 01:10 AM
Stripping tape removal KenKapt Gear & Maintenance 1 03-12-2004 10:36 AM
