butyl tape - Page 5 - SailNet Community
post #41 of 54 Old 04-26-2009
Originally Posted by Finallybuyingaboat View Post
Went by the local Marine store the otherday,and they have butyl tape, but it is $21/roll. Off to the RV Center one afternoon this week!
OUCH... the marine label markup is still alive and kicking.
sailingdog is offline
post #42 of 54 Old 04-28-2009
Very much alive and well.
I have been looking for some around here for a little while. Called several RV dealers that just shook their head.
Found one 20 mins away that has bags of the stuff. $6 for a 20ft roll. Happened to be in a Toronto marine store later in the day. $21 for something that looked to be about 1/2 the length, but it did come in a non-recyclable clamshell package.
jjns is offline
post #43 of 54 Old 04-28-2009
mitiempo's Avatar
If you're in Canada, Home Hardware sells butyl tape in rolls at very reasonable prices. Home Depot probably does as well, but I've not looked there.
Brian
mitiempo is online now
post #44 of 54 Old 04-28-2009
the pointy end is the bow
erps's Avatar
Home Depot, a 1 lb brick for under $2.00 as of one week ago.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #45 of 54 Old 04-29-2009
'87 Pearson 27'
jackytdunaway's Avatar
I had Grainger order me a roll of the 3" wide x 20' long but when i got it today one side had a cover on it that would not come off. I can find narrower but how do you use it in a large area like under a stanchion.
jackytdunaway is offline
post #46 of 54 Old 04-29-2009
mitiempo's Avatar
You can cut it to the right size with a sharp blade or if it is for a small area you can form it and roll it in your fingers like plasticene as I did under my winches (so it was just around the bolts in that case to keep the drain slots free of sealant).
Brian
post #47 of 54 Old 04-29-2009
'87 Pearson 27'
my concern was how to apply a 3/4" piece to an area that is 2-1/2" wide. Do you lay strips right next to each other
post #48 of 54 Old 04-29-2009
Maine Sail's Avatar
Yes and when you compress it with the bolts the strips become one big mass..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #49 of 54 Old 04-29-2009
Irrationally Exuberant
I lay strips right next to each other and then give them a little rub to join them. When you bolt down the stanchion you are going to get a whole bunch of it back when it oozes out all around. Not hard to imagine at that point that it has filled in little gaps and irregularities pretty well. Depending on the temp when this is all done, you might see some more squished out next time you get back to the boat too.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #50 of 54 Old 04-29-2009
mitiempo's Avatar
And then you cut the extra that has squeezed out with a razor and you're finished. It's the easiest bedding clean-up I've ever done.
Brian
Window gasket sealant.. groundhog Gear & Maintenance 39 07-11-2014 03:27 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 12:33 PM
Paininting non-skid... marinesniper Gear & Maintenance 36 01-29-2008 01:10 AM
Stripping tape removal KenKapt Gear & Maintenance 1 03-12-2004 10:36 AM
