Echo Charge drawbacks? - Page 2 - SailNet Community
post #11 of 13 Old 10-13-2008
Handsome devil
Stillraining's Avatar
Originally Posted by camaraderie View Post
Still...you have SEPARATE hookups for charging each battery with the truecharge and MONITORING each battery and DIVERTING current as appropriate. With a single bank charger and no electronic testing and diverting, the TOTAL charge of ALL banks is all the battery charger sees...So... if you have a house bank of 200 amp hours and a 100ah starting battery and you are down 100ah's on your house bank but full on your starting battery...a STANDARD 3 stasge 40 amp charger will see the 300 amp hour total charge down 1/3 and apply a full 40 amps to the total bank...not 1 amp to the starter and 39 to the house.
A bit oversimplified...but that is the reason to use an echocharger if one doesn't have a really sophisticated charger like yours.
Thanks Cam for taking the time to straighten me out..I'm sure it will help others as well with similar installations and the seemingly endless variables that get presented about it all the time...by the way Simple works for simple minds like mine...
Stillraining is offline
post #12 of 13 Old 08-18-2016
Re: Echo Charge drawbacks?
Hi emailed Sterling this:
Hi!
I am buying this product, being recommended by fellow cruisers:
Alternator to Battery Chargers up to 130A | Sterling Power Products
Need to know one thing though. I will connect it to my Gel house bank 300 Ah. The start output -> will connect to both start battery and windlass battery via relay.
House bank (bank 1) + start battery (bank 2) + alternator + Sterling will be near each other.
Windlass battery (bank 3) 10 m away!
I want to use a not so fat cable to the windlass battery and raise the voltage near the windlass battery. One of the purposes of the windlass battery is that it is way cheaper than the 150 mm2 cable (40 m total!) required from the house bank.
Do you have a echo charger or "inverter charger" I can put near the windlass battery. Am I asking to much to also get temperature sensing (I will not get that on the start battery with your product) on that battery (perhaps a feature of the echo charger/inverter charger)?
Sterling start output -> relay -> start battery (short way no need for volt raise) AND to windlass battery (long way need ro raise voltage). Not sure about the relay AND an echo charger though.
What do you guys think, please?
Read the net a bit, can't seem to find my exact scenario.
Cheers
bob666 is offline
post #13 of 13 Old 08-19-2016
So the Echo Charge only passes 15 amps? I'm using another combiner relay that's rated to pass 55 amps and since I have a 55 amp alternator it made sense to get that one. But a couple times now when checking the battery water I've found the house bank fine and the start battery dry. Looks like the combiner is passing too much current to the start side and boiling it out. So am I right in assuming the Echo is less likely to do that with only 15 amps passing over?
capt jgwinks is offline
lightning protection justified Gear & Maintenance 74 09-17-2008 07:07 AM
To charge or not to charge lyonsian Gear & Maintenance 27 05-13-2007 07:11 PM
Running Diesel To Charge Batts = Bad stoutwench Gear & Maintenance 30 04-03-2007 09:06 AM
Solar Power for Battery Charge KnotaClew23 Gear & Maintenance 1 09-23-2005 03:40 PM
