10-11-2008
Doodles, your surveyor should be able to tell you the ABYC requirements for the location, it is within x-many feet of the AC power connection to the boat. In practical terms, you locate it as close to the AC power connection as you can, in a place where you can reach and reset it.
That's assuming you are talking about shore-supplied AC, not a separate genset onboard. Gensets and inverters can be problematic because of the way they aren't always "really" grounded compared to shore power.
Personally? I'd stop down at the hardware store, and replace EACH of my AC outlets with a GFI-equipped outlet. They're all of about $5 each now, cheap redundant protection.
