Old 10-11-2008
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
Wipe on
I am trying a new product and wonder if anyone has had experience with it.
Petri makes it. It's called "Gel PolyFinish" Micro-Tropic Polyurethane - Satin Interior/Exterior.
It features: No brush application (it wipes on with a rag); No mess; easy cleanup. Two hours between coats, three or four coats recommended.
My question is: A year from now, am I going to be sorry I used it? I've seen it used on interior and it's okay, but I've never seen it on exterior. If anyone used this stuff a year or so ago could you tell me how well it holds up. And if it's as easy to maintain as it seems.
Thanks for your input.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
Old 10-11-2008
jackytdunaway's Avatar
'87 Pearson 27'
jackytdunaway is on a distinguished road
Are you usuing it on the interior or exterior. It sounds easy so i am waiting to hear if others have also. i am all about easy but many times it just sounds that way
Old 10-11-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
I've not used the product but am skeptical of using polyurethane products on the exterior. My experience has shown rapid degrading by UV light results. Sounds like it might be a good interior product though.
Old 10-11-2008
UV deterioration is also what I'm concerned about - but I'm using it on the exterior, to answer your question. And it is easy. I varnish boats for a living and when I get home I really don't feel like varnishing any more. So I cover all the faded gray teak on my deck with canvas and hope everybody thinks I'm just protecting a bristol varnish job!
BTW, I'm in the middle of my hard bimini project that I wrote about last spring. So far it's working out pretty well. I'll report on it (with progress pix) when I get it done and looking spiffy!
Old 10-11-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
From all that I have ever read varnish holds up much better then polyurethane products in exterior applications.
S/V Scheherazade
Old 10-11-2008
Did you mean interior?
Old 10-11-2008
Nope, I meant Exterior. The package says Interior/Exterior. And it also says UV protection.
We'll see. You're probably right that varnish will hold up longer. But 2 coats of sealer and six coats of varnish to begin with and then maintenance coats every six months or year is more than I want to fuss with. And I can't afford to hire someone like me to do it.
If this stuff will last a few months and I can just wipe on another coat and go back to my rum drinking I'll be a happy sailor.
Like I said, we'll see. If nobody else has experience with the stuff, I'll just have to be the guinea pig. I'll let everybody know next spring, after the autumn sun and the winter have had their way with it. And if it makes it through the summer - wow, there IS a god!
Old 10-11-2008
Freesail99's Avatar
Isn't that where varnish excels also, a light sanding and re-apply. I am not sure you can do that with Polyurethane. Wipe or brush on.
S/V Scheherazade
Old 10-11-2008
T37SOLARE's Avatar
Tartan 37C
T37SOLARE is on a distinguished road
Never seen or heard of a Polyurethane that can actually survive in a marine exterior environment. My feelings are if their was one everyone would be all over it. Caveat emperor comes to mind.
On the other hand, I'm looking for a good INTERIOR satin finish, and this might just fit the bill. What's you experience with it as an interior finish?
SOLARE
T-37 #442
Old 10-12-2008
soulesailor's Avatar
blue collar cruiser
soulesailor is on a distinguished road
I've used wipe-on poly many times. I've found it's good for touching up existing poly surfaces that have been scratched for some reason or another. The wipe-on is very thin and more or less wipes right off the existing poly coats but remains in the crack, adhering to the scratch like it had been sanded by a one grit shoe sole.
I tried to coat some new wood with the wipe on, hoping to build up layers, but it just didn't seem to work nearly as well as brushing on poly in the normal manner. However, I wasn't using the same exact product you named.
who is staring at the sea is already sailing a little
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 3 Weeks Ago 06:02 AM
cleaning teak chuckg5 Gear & Maintenance 56 01-12-2009 12:45 PM
What paint to use dsmylie Gear & Maintenance 10 04-28-2007 07:26 AM
removing sail numbers sedavis General Discussion (sailing related) 5 12-20-2000 05:03 AM
