10-12-2008
Originally Posted by NorthUp
Is the position suitable for through- hull log or sounder transducer- doesn't look like it in the photo, too much of angle?
Is there an optional cabin layout for your boat from the builders- maybe suitable if heads are in another location on different model.
Definitely not a transducer fitting there... wrong type, and as you say, wrong location.
Could be the liner was meant to be cut out to make way for the seacock/valve for some optional plan, but since it's useless now as is, and is not presenting a problem (and not prone to accidentaly impact due to its location) it's probably best left alone, as the ever-clever JRP suggests.
1984 Fast/Nicholson 345
