How to spruce up molded in non-skid deck??? - Page 2 - SailNet Community
post #11 of 31 Old 10-13-2008
Pamlicotraveler's Avatar
I recommend Flood's Penetrol, a low viscosity penetrating oil. It works like Armor-all on a car. Your deck needs to be clean first, and make sure its going to have a while to dry and don't put it on too thick...very thin layer with a rag, wipe off surplus after 2-5 minutes, before it gets tacky...and your boat will shine until you have to do it again. If it's too thick it will run after it dries and looks like spilled varnish and can attract dirt.
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #12 of 31 Old 10-13-2008
sailboy21's Avatar
Originally Posted by Banshi View Post
I painted mine and I did not have any problems with "pooling" paint. I used interdex nonskid and put it on with a roller cutting in at the edges where the color changed with a brush. If the paint is pooling your putting to much on at a time. It took two coats on mine. The moulded non skid areas a giege and the flat areas ( I used non skid paint in these areas as well) are white. This is probably the best picture I have.........but you can clearly see the moulded non skid is still there and the deck is far grippier now...........
Good job. Another satisfied Interdex user.. Did you sand your deck at all? I pretty much annihilated by molded non-skid, but that was only to removed the last guys paint attempt. It says it sticks to properly de-greased gel-coat. I would bet Banshi here used a drill attachment paint mixer. I did a couple small sections hand stirring that looked like crap. Stir stir stir!!!
sailboy21 is offline
post #13 of 31 Old 10-13-2008
We used Interdeck on our cockpit sole after removing aged glue-on non skid which left smooth gel coat behind. Once the glue residue was scraped away a light sanding was all we did. Two seasons later it looks good and grips well.
Faster is offline
post #14 of 31 Old 10-13-2008 Thread Starter
A gentle lesson on terminology for you here... the "topsides" of a boat is the area between the waterline and the deck edge - ie the surfaces of the hull itself above the waterline.
I thought that was Freeboard. I thought topsides was anything above the hull deck seam or above the gunwale. Anyway, you are correct. I should have just said deck.
Banshi, that looks very nice. It does appear that we may have a different type of molded non-skid. Mine is almost like mini diamonds on end all compressed together. Probably 1/4" deep and rather pointed on top. Actually can be uncomfortable with bare feet.
When I attempted to paint it, the paint tended to level itself into the recesses of the non-skid and expose the points. Plus each little recess between the points ends up with a different level of paint so I looks rather sloppy. Perhaps as suggested I should just sand out the texture and paint it with interdex.
SiXeVeN is offline
post #15 of 31 Old 10-13-2008
Banshi's Avatar
Interdeck is pretty thick, if you have not tried rolling it I would give it a try before I went to the trouble of sanding it down unless of course you just wanted to go ahead and get rid of the diamond points anyways. A orbital pad sander with some 80 grit paper would probably make quick work of it. Don't forget to clean the surface with some sort of form release solvent.
1976 Chrysler 22 "CinJam"
Banshi is offline
post #16 of 31 Old 10-13-2008
Are you using the penetrol for cleaning or for finish coat? I think you are saying you use it for a finish coat but I'd like to be sure.
I'm having trouble getting diesel spot stains out of the non skid.
xort is offline
post #17 of 31 Old 10-14-2008
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
I painted my non-skid areas with Durabak 2 years ago and am happy with the results. It is very easy to apply, the color is uniform, and the traction is fantastic. It goes on thick and easily fills small cracks and chips.
Durabak Company; Truck Bed, Marine, Boat Ship Industrial & Workplace Non-Skid Coatings.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
post #18 of 31 Old 10-14-2008
A caution on Penetrol (not a cleaner, btw) - it's extremely effective at "restoring" chalky gelcoats, esp the deeper colours.. but it's temporary and makes subsequent painting difficult. All traces of it must be removed prior to painting,- it does "penetrate" the surface so it's difficult to know for certain it's all gone - and could lead to unsatisfactory results with the new coatings.
Heinzir: Pretty shippy little boat!! Nice.
Faster is offline
post #19 of 31 Old 10-14-2008
Wayne25's Avatar
I second the power washing and Woody Wax. Its worth a try and you can always remove the wax and paint it if it doesn't meet your satisfaction. We use it on my cousin's fishing boat and it keeps the non skid looking new. Easy to apply, follow directions.
I have used Penetrol on chalked gel coat. Looks ok when first done, but it doesn't last long and is a pain to remove.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #20 of 31 Old 10-15-2008
No...It's definitely not a cleaner. It has just been the only thing I have found that would clear up the chalkiness on our 20 year old nonskid and make it look glossy again. It is temporary, but so is a cleaner if you think about it.
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 08:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
