Old 10-12-2008
dave6330 is on a distinguished road
Stuck Fuel Guage
Problem: The guage for my diesel tank seems to be stuck on full. When powered off, the guage drops to 'empty' but when turned on, pegs out on 'full' even though I know there's less than a full tank. I've found what I believe to be the guage on the top of the tank (a plate screwed on with calking around it and wire leads). I know it sounds like I'm a simpleton, but does introducing air into the fuel tank cause any problems? I wouldn't think so but the last thing I want to do is break something with my tinkering.
Question: What landmines are involved if I simply remove the calking, unscrew the plate and pull the guage to see if it can be unstuck?
[/SIGPIC]Dave
Sailing out of Seward, Alaska
"Fight the good fight, holding on to faith and a good conscience. Some have rejected these and so have shipwrecked thier faith"
Old 10-12-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Its not a "pressurized system", so remove the sensor sending unit from the tank as you like. Sometimes those floats will get crud on them and stick like that.
-- Jody
S/V "
1983, Barberis Show 38! or
Old 10-12-2008
Quickstep192 is on a distinguished road
As an added safety measure, I'd be certain to make sure all power is off and remove the sender wire before taking it out.
Old 10-12-2008
Rockter will become famous soon enough
You will not lose much by looking at it, and it is probably easy to re-seal it.
In the tank, you have what's known as the "sender"... a form of transducer. The guage (presumably elsewhere) , gives you the reading. The guage is really a current measuring device. Probably the sender float is just stuck in the up position. If a wire was broken, or had fallen off, I would expect it to read nothing all the time.
I don't think the sender float has flooded, otherwise it would read empty all the time.
It's worth a look to open it.
It is very easy to test them... you just push the float up and down and watch the readings.
Beware if the tank is a gasoline tank. Gasoline is very unforgiving. All your testing wil have to be remote, with the float taken out completely and no power delivered to it until it is.
Is it a diesel tank?
Old 10-12-2008
Thanks guys. As I said, it's a diesel so I don't think I risk explosion or anything. I WILL cut the current when I check it out until I have the sender out. If I have to replace the unit, are they hard to match up with the OEM product? The boat was made in sweden and I might have some trouble tracking down an exact match.
[/SIGPIC]Dave
Old 10-12-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Let us know what you find. I have the same symptom on one of my gauges but I am suspecting a short circuit somewhere rather than a mechanical fault.
Trouble is, I can't remove the sensor from the tank without removing the tank and to do that, I have to remove the engine.
Jonathan-Livingston
Old 10-12-2008
SteveInMD is on a distinguished road
I just went through this over the summer. I replaced the sender. Normally you do not need to go back the boat manufacturer to find a replacement.
Sometimes you can run into problems getting the tank to seal when you put it back together. The key clean off the old sealant, then use something like Permatex RTV sealant when you put it back together. Do not over tighten the screws when you reinstall. You don't want to squeeze all of the sealant out for this type of seal. You wont know if you have a good seal until you either fill the tank to the top so you have diesel sitting in the filler hose, or you go sailing and heel the boat over with a nearly full tank. Keep a close eye on it until you are sure it is sealed properly.
Old 10-12-2008
ianhlnd's Avatar
A little less cheek
ianhlnd will become famous soon enough ianhlnd will become famous soon enough
The best fuel guage is a stick. If it breaks, get a new stick.
Just checking in.
Where ya'll keep'n the wimmin 'round here?
Old 10-12-2008
billangiep's Avatar
billangiep is on a distinguished road
I'm with ianhlnd on this one..I call mine a story pole, I used a dowel and put markings and notches at every five gallon point then varnished over it. Another idea if you can' insert a dowel is to string some wooden beads together with a colored bead at each 5 gal. point?
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
Old 10-13-2008
Also you could replace the electric gauge with a mechanical one. The gauge sits right on top of the access port. They are much much more reliable then the electric ones. The reliability far outweighs the slightly less convenient placement for reading the fuel level.
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 31 03-22-2012 02:36 PM
Myth of Condensation in Fuel Tanks Martinini General Discussion (sailing related) 47 08-03-2009 01:22 PM
Universal M21, long story and fuel line question BarryL Gear & Maintenance 16 05-12-2008 03:37 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
