Solid Forestay - Page 3 - SailNet Community
post #21 of 44 Old 10-15-2008
Omatako's Avatar
I had rod rigging on a previous boat years ago and had no problems with it other than tuning the rig is more difficult and probably not manageble for the amateur. I'd have it again if it weren't so expensive.
My interest in this thread is I trust the OP is replacing part of a rod-rigged vessel's rigging and not mixing rod with wire. I'm pretty sure that would be dodgy.
Arthur C. Clarke
Omatako is offline
post #22 of 44 Old 10-15-2008
My understanding is that rod rigging is actually harder to inspect as it gives little, if any, warning prior to failing. Wire rigging generally will meathook and break strands before it fails.
sailingdog is offline
post #23 of 44 Old 10-15-2008
I guess it comes down a little to what you mean by inspection. If you are seeing meat hooks in wire, then I'd say you went to far before doing a thorough inspection. You can drop rod rigging and use an inspection dye on all the rod heads. If rod is going to go, it is the cracks in the heads that will most likely go. Like wire rigging, you are more likely to suffer a rigging failure in a one of the connecting components, such as a turnbuckle, a toggle etc.
On the Navtec site is a good description of what a thorough inspection of rod rigging should entail. This is the kind of inspection I was referring to. Something that might be done before setting off on a long voyage while setting up a cruising boat. The walk around the boat and look at the rigging type inspection is another story.
Paul L
Paul_L is offline
post #24 of 44 Old 10-15-2008
I believe that the FURLEX provides a wire forestay w/norseman type terminal with their furlers - in the belief that wire better suits the furling scenario. It would not be unusual for such a furler to be installed on a boat that otherwise has rod rigging...
We had rod rigging on a previous boat - and had two failures in 12 years. One due to a procedural error by an unknown rigger - the other due to inadequate maintenance/inspection.
In the first case a deck stay (between mast step and deck) failed because the cold formed end had actually been welded to the fitting. In the second, the cold formed end and its fitting had dried out and essentially siezed in place.
Rod rigging that has been released immediately goes into a bit of a spiral (it is stored in a large radius coil) It does not lay straight on the ground. This "spiral" tendency means that as the stay loads/unloads there's actually a torsional "twist" that should be absorbed in the fitting - ie the cold formed end needs to be able to "move/rotate" a little. If this does not occur, the rod will fatigue and fail from the repeated twisting as it leaves the fitting.
In both our failures, this was the cause. In the first case the rod had been welded, in the other the socket seized up - the result was the same. Fortunately for us we saved the rig on both occasions - and after the second event spent some considerable time inspecting and freeing/lubing the remaining rod ends.
Faster is offline
post #25 of 44 Old 10-16-2008 Thread Starter
Not Rod - my mistake
Sorry, I guess the item I'm talking about is rarer than I'd hoped and I didn't specify. What I have is a sold forestay which for most of it's length, i.e., except the bottom and top ends, is about one inch wide by 3/8 inch thick in an approximately flat oval shape. However each edge is slotted to hold the boltrope on the luff of my foresails. I'd provide a picture if I could figure out how.
I'm located in eastern Ontario Canada and what has happened is my forestay was bent about 90 degrees when it was stored on my boat on the hard when it was caught by the shroud of a passing day sailer being towed to be launched.
Thank you all for contributing and I learned a bit about rod rigging. However I'm still looking for a supplier and any assistance would be appreciated.
va3wmh is offline
post #26 of 44 Old 10-16-2008
What you're talking about is a headfoil. There are several brands available, Tuffluff (generally plastic) and others. The one you describe with a slot fore and aft is an older style, I forget the namebrand. It's not as user friendly as newer foils which have both grooves facing aft.
Your forestay should run inside the foil... its unlikely that the foil is acting as the forestay itself, but I believe there were such versions.
Since it's damaged I'd suggest going to a rigger and replacing it with a more modern version, of which several makes are available. If you indeed have a combined foil/stay, you'd really be better off replacing it with a conventional forestay and foil (or furler if you want). You likely won't find a direct replacement new.
Faster is offline
post #27 of 44 Old 10-16-2008
Yes, as faster said, what you've got is an aluminum foil over what is probably wire rigging if the rest of the boat is wire, rod if the rest of the boat is rod...
If the forestay is integral or has swaged fittings, you're probably going to have to replace it.
post #28 of 44 Old 10-16-2008
IIRC (and not sure I do) the combined stay/foil such as you describe was made by Streamstay.... Don't believe they are made anymore.
You'll be happier with a newer version, which I assume the other guys insurance (or the yards) will pay for...
Faster is offline
post #29 of 44 Old 10-16-2008
Thanks Courtney.
You're not likely to be able to seperate the damaged/bent foil from the wire forestay. Find a local rigger and install a new forestay and foil. (Keep the old damaged one. It will help with measurements for the new.)
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #30 of 44 Old 10-16-2008
Would you please, for the love of God, go to the off topic forum and get enough posts to attach a picture or email one of us a picture so that we can post it here.
No one knows for sure what the heck you are talking about.
knothead is offline
Irwin Citation 34 Inner Forestay TomandKarens34 Irwin 1 09-07-2009 01:15 AM
SO 43 releasable inner forestay JoeKerridge Jeanneau 11 06-21-2007 06:06 PM
Correct forestay diameter? wysiwyg Gear & Maintenance 8 04-15-2007 06:02 PM
Solid Engine Mounts zerubb Gear & Maintenance 7 07-03-2006 10:53 PM
Heaters: diesel or solid fuel? Seagypsywoman Gear & Maintenance 9 12-29-2004 02:22 PM
