10-15-2008
Originally Posted by daniel9331
Many thanks for your comments. On the boat that I'm looking at, the pumping mechanism is located in the cockpit, which seems like an odd place from which to adjust a vang.
In fact, it's the ideal place to do it because you can, from the cockpit floor sight up the mainsail and see the results immediately.
How much pumping is involved to adjust the vang? Is the adjustment as quick as a block and tackle? Also, am I correct that the hydraulic vang provides significant upward support?
It's not as quick as a mechanical vang, but you have more control and it takes less effort. Some hydraulic panels have a "dump" switch that allows you to dump the hydraulic pressure in a hurry... say if you're broaching and have to get the vang "off" in a hurry. In multiple port panels (eg Vang, outhaul, backstay) make sure you're selected to the proper port before you make adjustments - especially sudden large ones. It can get exciting when you're "dumping the vang" only to realize that the vang hasn't moved and suddenly your backstay is slopping around like a wet noodle.....
The released vang will support the boom - a handy feature in light air (admittedly provided by spring loaded vangs too, but again, better control and easier access)
Try it ... You'll like it!
