10-16-2008
Tartan 37C
If you have the time to do it right, you actually did good. You want to seriously thin the first coats so the varnish can penetrate the wood for better adhesion. I would do another coat at 60% varnish to thinner then 80% and then a minimum of 4 coats of 90-100%. The next year you should do 2-4 coats, then you can get away with 1 coat a year, unless you in the tropics (then double everything!)
SOLARE
T-37 #442
