Originally Posted by MeCaptainBinky
Meralon or Brass
Marelon or Bronze and NOT brass. Either is good but Marelon can be quirky and of course Bronze can corrode..
Round or triangle
Does not matter as long as it has a flange that can be bolted or screwed into the backing block.
We are going offshore -
Can we do meralon?
Will triangle base seacocks work?
Marelon is fine but it MUST be lubed yearly, which can be a PITA, and they must be exercised regularly. There are many reported failures of Marelon handles due to lack of maintenance/use.. I had three failures early on with Marelon and I was lubing them and exercising them. I'd use them today, I believe they addressed the failure issues, but the company pissed me off so badly and refused to stand behind the product, even with KNOWN defects, that I won't buy any Forespar products if it can be avoided..
What are the drawbacks of meralon?
Other than yearly lubing, which requires removing the hose on the inside and using a flux brush to apply a grease to the ball and then lubing the outside in the same manner, nothing. I do believe they have their handle failures under control unless you don't maintain them.
What are the drawbacks of Brass?
There are many types of Brass but suffice it to say you should not be able to find a "brass" flanged seacock from any of the big suppliers, Spartan, Buck Algonquin, Groco or Apollo and they will all be bronze if they have a flange.
You do not want to use any brass, unless it's marine rated red brass, bellow the waterline and this includes the fittings and hose barbs associated with the bronze seacock. Most brass these days is yellow brass or cheaper that has a very high zinc content and we all know what happens to a zinc...
You may want to strongly consider a Groco bronze flanged seacock adapter. If a seacock should fail you can replace it in just about any country in about 5 minutes even with the boat in the water..
Someone has already linked to my seacock articles so I won't reapet that here.. Good luck!
