Old 10-16-2008
Sea Slacker
brak is on a distinguished road
Trickle charger
I just bought Promariner 1.5 maintenance charger. I connected it to all my batteries (total of about 500 amp hours) and it does seem to pull them up to 13.2v, but the charger is really hot. Am I using it with too much battery? Is that normal for chargers to be hot?
Also, can I leave it on for, say, 3 months or should I turn it off sometimes?
Old 10-17-2008
sander06 is on a distinguished road
With all due respect, try asking the manufacturer...
ProMariner :: Contact Us
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
Old 10-17-2008
Sea Slacker
I already did that, with little effect.
I am interested in opinions or experience of those who use these products.
Old 10-17-2008
Brak-
Why buy a trickle charger? Why not buy a bigger charger that has a float mode. It would work better, be more versatile and heat up a lot less.
Old 10-17-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
"Warm" is one thing, but "really hot," for anything electronic (other than glow bottles) is usually considered a Bad Thing. I would be suspicious. I would disconnect the thing. I think I'd go looking for a battery maintenance system that didn't run "really hot."
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-17-2008
Sea Slacker
I have a charger with float mode, but it's on a boat and I keep batteries at home this winter. So that's why a trickle charger.
There aren't many choices out there - this Promariner thing seemed on the money but they have no customer service, apparently.
Old 10-17-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Don't leave all your batteries connected!!!! No no no!!! A bad cell in one, or even one just a little more tired out than the rest could damage or destroy them all over the winter. If you are determined to use a trickle charger get one for each battery.. Or if they are near a window get a 1.5 Watt solar panel for each one.
Old 10-17-2008
Sea Slacker
These batteries are all the same vintage and they are always connected when on the boat. No reason to do it any differently at home. If I get any bad cells - it's time to replace them all at once, and that's just what I'll do.
I actually ran some numbers and it looks like I may only need to run the charger an hour or two per day. I thinl I will get a timer to control it.
Old 10-17-2008
SEMIJim's Avatar
Bad idea, IMO, brak. But it's your property to burn down if you want.
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-17-2008
waltsn is on a distinguished road
Is this the spec for the charger?
"Fully Automatic - Designed to maintain 12 volt batteries up to 250 amp hours
Increase Performance - Precision regulated 13.4 VDC float mode. Can be left on for extended periods without overcharging or damaging batteries. Will not drain battery if AC is removed. LED status indicator. User adjustable for gel's.
Built-in Safety - Reverse polarity protected. Certified to U.L. 1236 Marine."
Id leave it connected to your battery bank for a while longer and see what happens. If its regulated, you should be able to leave it connected and forget about it. Getting very hot should be watched carefully but it may just be that the "little" charger is trying to bring 500 amp hours of battery up to charge (which exceeds the spec) and they may have been low in the first place.
The one thing which I would be slightly worried about is temperature. The charger looks like it may not have temperature compensation and battery charging voltage's are temp sensitive. They need to be lower for high temps, higher for low temps. I would guess however if your batteries are in your garage or similar, no matter how cold a place where you live, you likely wont have a problem.
charger choice - Prosport 12a or Guest 10a Northeaster Gear & Maintenance 20 07-21-2008 10:17 AM
Battery Charger zaldog Gear & Maintenance 32 08-07-2007 08:47 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
Problems w/ Prosine 2.0 Inverter Charger verticalmoves Gear & Maintenance 2 10-04-2006 09:33 AM
Multi-Bank Charger Installation titan151 Gear & Maintenance 0 06-29-2005 08:25 AM
