Sta-Lok or ? - SailNet Community
Blogs
Old 10-17-2008
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
Sta-Lok or ?
I have no experience with user-installed wire terminals like Sta-Lok, Noresman or others. I have to shorten my running backstays and thought that it would be a good opportunity to learn about these. Does anyone have recommendations about which ones are easiest to use, most reliable - are they basically the same or are there significant differences that I should know about?
Thanks
Old 10-17-2008
I like the Hayn HiMods, since they're a bit simpler to use IMHO. They have a crown ring that the wire ends slip into, and it is easier to fit them properly than the StaLocks or Norseman fittings. None of the various brands is all that difficult to use though.
Old 10-17-2008
Paul_L is on a distinguished road
Thanks
Sta-Loks are reasonably easy to install and last a long time. If this is running backs you are doing, why not switch to rope for them? Less chafe on the sails, long life, probably cheaper to install then wire. Look at lines like Amsteel.
Paul L
Old 10-17-2008
knothead's Avatar
Thanks
Check out the Suncor quick attach fittings before you make your final decision. Probably the simplest to install and from what I understand, one of the strongest.
Ron Paul 2012
"wikijar"
Old 10-17-2008
I already have the wire
Paul L
The wire stays are already there and in virtually new condition. For some reason, the POs of my boat (Bristol 45.5) led the runners through a turning block (not a particuarly good lead at that) and then to secondary cockpit winches. I am going to use tackles for the runners and need to make each about 18" shorter. I might consider Amsteel or something similar for a future update
Old 10-17-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Hi-mods are very easy to install and unlike the other terminals they are completely reusable. I had to buy one Norseman fitting due to a backorder at Hayn... Compared to the hi-mods it was way more complicated to install and had a lesser finish quality to it.
But for running backstays: go synthetic. I have had a set of amsteel stays that have aged quite well. They are easy to splice, very low stretch, and best of all easy to take down and stow bellow.
Old 10-17-2008
Valiente's Avatar
I have dacron running backstays and blocks, Bruce, as well as twin wire stays...probably overkill. I also have Sta-Loks all around that are really solid looking.
I think between Sta-Lok, Hayn, and Norseman, it's the rigger that makes the difference, not the terminal. I have rarely heard of one of these terminals failing unless, you know, the wire was falling to bits.
I have heard of Suncor in terms of chain and shackles, not terminals, so can't comment.
Old 10-17-2008
If you're doing the installation yourself, the Hayn HiMod are far simpler to use... the crown ring makes getting the wire seated properly much simpler.
If you're paying a rigger to do it... you're short-changing yourself, since you're not going to have a rigger if the rigging fails out on the water. Also, if you go with the Norseman or StaLoks....carry extra cones.
Old 10-17-2008
RichP is on a distinguished road
My local rigger recomends Sta-Lok over Norseman for the self fitting, i can't remember the exact reason, but it was something about Norseman having a slight flaw that would let them split in some circumstances or something. I would take that with a pinch of salt because Sta-Loks cost more here and i wouldn't put it past him!
Properly installed both should be ok, and both are easy to fit.
Hi, i'm restoring my old quarter tonner on a budget! Read my blog if your interested!
Old 10-17-2008
knothead's Avatar
I also would recommend Staloc over Norseman if the choice were between the two. I've seen fewer failures with Staloc.
Some of the newer fittings like the Quick Attach are different in that you don't have to unlay the wire when assembling.
As I mentioned in another thread, I haven't had any reason to start using the fittings in my business but if they work as advertized, I can see some real advantages for the do it yourselfer.
I haven't really used the product yet and therefore can't recommend it but if they want to send me a couple, I'll try them out.
Here's a video that shows the fittings and how they are assembled.
Ron Paul 2012
"wikijar"
Sta Lok system rbtpfe9 Gear & Maintenance 10 11-15-2009 06:31 PM
Splicing Sta Set X line jsfletch Gear & Maintenance 2 06-25-2001 08:56 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
