Engine Installation; advice required! - Page 2 - SailNet Community
post #11 of 19 Old 10-18-2008
OK - it should be pretty straight forward to mount the aquadrive then.
FYI there is a guy building out a Westsail 42 who went through this process....his site is here: Building a Westsail 42 Sailboat, From a Bare Hull
and pictures of the shaft installation are here: Picasa Web Albums - rl - Building a We...
Originally Posted by RichP View Post
An alignment of up to around 4 degrees is apparantly acceptable with aquadrive, some people use it to mount the engine flat.
There is another boat with a 1gm using the standard mounts, but his installation imo has the p-bracket a bit to far aft to use a folding prop. (His is 3 bladed)
The outboard is not acceptable for the boat, the prop regularly cavitates with even a moderate swell, and its a pig to get up and down!
GBurton is offline
post #12 of 19 Old 10-18-2008
Sorry for the double post, just spotted this, on all the others i have seen, the propshaft passes through the skeg. The bearers are not that steep at all when you see them.
I figured the outboard was problem propulsion-wise
Will it be possible to use a long enough stern tube that your stuffing box gland is not buried within the skeg? Do you have good enough access to solidly mount the strut and cutlass bearing, presumably to the bottom of the skeg? I like Mainesail's idea of mounting the cutlass and "sighting" the propshaft location with a laser pointer.
Faster is online now
post #13 of 19 Old 10-18-2008 Thread Starter
I certainly don't plan on the stuffing box gland being inside the skeg, its quite a shallow skeg, all things considered. There should be enough length as i have seen an aquadrive installation with a 1gm10 on a boat with less room than this. (Newbridge Corribee).
A possible idea i have for alignment i have just had is to, bolt stainless angle onto the engine bearers, this can be bolted sideways through the bearers, and the top can be drilled and tapped for the mounts when i have the dimensions.
Then place the engine dead centre within the boat and affix something straight (i.e. broom handle that isn't warped) into the gearbox output flange, the engine can be slid back along the bearers until this contacts the hull, this is my stern tube location. (Obviously measure thrice, check twice, cut once!)
I can then bolt the aquadrive onto the engine, and the shaft onto the thrust bearing of the aquadrive and shift everything about until i have the shaft as central as possible and the engine as close to the aquadrive centre of movement as possible. (i.e. if it allows movement 2.5cm in either direction when in the 'middle', as close to that as possible.) the aquadrive can then be solidly mounted in place and the p-bracket location determined.
After this i would again try and align the engine as closely as possible and mark the centres of the mount holes on the angle steel, remove it, drill, tap it. Jobs a good 'un!
Obviously that theory will need tweaking... can anyone see any major problems?
Hi, i'm restoring my old quarter tonner on a budget! Read my blog if your interested!
RichP is offline
post #14 of 19 Old 10-18-2008
You don't mention a strut/cutlass bearing in your plans... If you're planning to use one (which I'd expect) it seems that that's the angle that's going to dictate where everything else goes.
But having never purchased one, perhaps they're available in a suitable variety of angles.. or perhaps you have something else in mind..
Using SS angle iron to create the appropriately angled and spaced bed for your mounts works well, we've done that before ourselves, esp if the existing beds are good and solid.
post #15 of 19 Old 10-18-2008 Thread Starter
Luckily my father has a friend who does a lot of fabricating in stainless steel, and he has agreed to make a P-Bracket to suit.
RichP is offline
post #16 of 19 Old 10-18-2008
Engine change special report
Greetings from New Zealand. I saw your engien change post. Here is an article I did that might help.
Thanks
Yachtwork
044 Edit TAB166 (Large).jpg   045 Edit TAB166 (Large).jpg   046 Edit TAB166 (Large).jpg   047 Edit TAB166 (Large).jpg   048 Edit TAB166 (Large).jpg
yachtwork is offline
post #17 of 19 Old 10-18-2008
Engine change part 2
Here is the rest of the article. You migh thave to use Ctl + to zoom to read.
Cheers
Scott
Yachtwork
049 Edit TAB166 (Large).jpg   050 Edit TAB166 (Large).jpg   051 Edit TAB166 (Large).jpg
post #18 of 19 Old 10-18-2008
ancient mariner
captbillc's Avatar
engine installation
RichP i have a yanmar 2GM20F in my 30 nimble express with the aquadrive.the constant velocity U joint in the aquadrive allowed the engine to be mounted horizontally, it was installed in 1994 when the boat was built and has never given any trouble. the thrust bearing in the aquadrive is bolted to a 3/8 aluminum plate whjch is bolted to supports in the hull. with this setup i never have to worry about engine alignment. your used aquadrive should have the u joint & bearing checked before installation. this setup allowed the engine to be mounted on soft mounts to eliminate transfer of engine vibration to the hull. i can take a picture of it & post it on an email to you. i have not figured out how to post pictures to this site yet.
EDIT...here it is:
captbillc is offline
post #19 of 19 Old 10-18-2008
Easiest way to post photos to this site is to use an external photo hosting site, like Flickr.com or Photobucket.com, and then link to the photos here. Directions for doing so are located in the POST in my signature.
Originally Posted by captbillc View Post
RichP i have a yanmar 20GMF in my 30 nimble express with the aquadrive.the constant velocity U joint in the aquadrive allowed the engine to be mounted horizontally, it was installed in 1994 when the boat was built and has never given any trouble. the thrust bearing in the aquadrive is bolted to a 3/8 aluminum plate whjch is bolted to supports in the hull. with this setup i never have to worry about engine alignment. your used aquadrive should have the u joint & bearing checked before installation. this setup allowed the engine to be mounted on soft mounts to eliminate transfer of engine vibration to the hull. i can take a picture of it & post it on an email to you. i have not figured out how to post pictures to this site yet.
sailingdog is offline
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 41 09-23-2016 11:03 PM
Rebuild vs replace diesel engine Ilenart Gear & Maintenance 40 02-21-2010 10:23 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Safety Check Mark Matthews Learning to Sail Articles 0 01-25-2000 07:00 PM
