last bit of water from the bilge - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 10-19-2008
Since Cam hasn't mentioned it yet....
  #12 (permalink)
Old 10-19-2008
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
Wow!!!!!!!!!!!!
Bob T
"I cannot not sail" - E. B. White
  #13 (permalink)
Old 10-20-2008
heinzir's Avatar
Junior Senior
heinzir is on a distinguished road
I'm sure someone will correct me if I'm wrong, but I believe most centrifugal bilge pumps need to be primed in order to work. This is accomplished by having the pump submerged in the bilge water. When the water level drops to less 1/2" or so the pump loses its prime and stops working. Also, most automatic switches shut the pump off long before the bilge is bone dry. The solution, as I see it, is to have a second, different type of pump and/or use a solid state water sensor rather than a float switch. I have the intake hose of a manual diaphram pump set in the lowest part of my shallow bilge to pick up what the electric one doesn't. It also serves as a back-up.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
  #14 (permalink)
Old 10-20-2008
No pump solution is likely to keep your bilge bone dry. This is due to the problems with float switches, pump priming, etc...
1975 Ranger 23: bit of water over the keelbolts Chompy Boat Review and Purchase Forum 9 05-09-2006 11:16 AM
Odor Control Kathy Barron Her Sailnet Articles 0 09-02-2003 09:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
Water in the Bilge Dan Dickison Gear and Maintenance Articles 0 03-12-2001 08:00 PM
Bilge Pumps:First and Last Lines of Defense Tom Wood Seamanship Articles 0 05-20-1999 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
