My Project Boat - Page 57 - SailNet Community
 2Likes
post #561 of 577 Old 06-23-2012
Question Re: My Project Boat
Update on the outboard repair:
I took it to a guy who specializes in outboards. I asked him if he could show me how to replace the water pump so I could do it on my own next time around. He was more than happy to show me, I think he was thrilled to have some company! The bottom part of the outboard did not want to come off very easily. When we did get it out we found that the impeller was in okay shape but the plastic housing covering it was very blistered from heat. The problem was inside the engine, where he believed that there was blockage. He is going to rebuild it for me for $700.00. Is that a good price? This includes the parts (head gasket, etc). I had already tried scraping out the pee hole way before bring him the outboard. Thanks for the tip though!
Green with envy is offline
post #562 of 577 Old 09-30-2012
Re: My Project Boat
Hi AllThumbs,
I have been reading your renovation posts with interest as I have just bought a DS22. I don't think mine needs too much doing to it, I hope! Def needs some varnishing, a few minor repairs to the gelcoat etc. One thing I don't know about is the swing keel/centre board as I bought the boat on the trailer and won't launch until next Spring. I'm hoping that I can get it down when I launch and that with a bit of lubrication (somewhere?) that it will go back up again now and then. Anyway, I was wondering if you had any advice in this department, or any pictures maybe. I'm guessing the DS20 is very similar to the DS22? I tried searching on SN for this topic without much success.
Thanks
Richard
rtawood is offline
post #563 of 577 Old 09-30-2012
Re: My Project Boat
I should have read your most recent posts first, as I now see you have dropped the centre board and supplied pictures as well! doh
rtawood is offline
post #564 of 577 Old 10-01-2012
Swing keel pivot question
Having now read your excellent posts and viewed your excellent pics of dropping the centre-board, I have a few questions. How did you get the cover off the pivot pin and how did you get the pivot pin out? Was it easy? Looking at my DS22 on the trailer, I can't even see where the pivot pin is. So I'm guessing its buried beneath a lot of paint!
Looking down into the centre-board casing it seems that my centre-board is hoisted up and down with a nylon strap. Not sure if that is bad thing or not. There is no winch to turn either, just a rope that you pull through a cam cleat.
I probably should overhaul the lot.
Richard
rtawood is offline
post #565 of 577 Old 12-26-2012 Thread Starter
midlife crisis member
AllThumbs's Avatar
Re: My Project Boat
rta,
The DS22 is a different animal altogether. Different designer. You should join the DS20/22 yahoo group: DS20-22-DillerSchwill20-22 : DS20&22 DillerSchwill20&22
AllThumbs is offline
post #566 of 577 Old 11-03-2013 Thread Starter
AllThumbs's Avatar
Re: My Project Boat
I am working on a new rudder. Here I am vacuum bagging a 1" ply lamination carved into an airfoil shape. 3 layers of 9 oz glass on each side.
Then, out of the bag it's being faired with epoxy mixed with fairing filler.
I sail.
post #567 of 577 Old 11-03-2013 Thread Starter
AllThumbs's Avatar
Re: My Project Boat
The upper section is made from 1/4" fiberglass sheet. Here I am gluing additional strips as stiffeners.
I sail.
post #568 of 577 Old 11-03-2013 Thread Starter
AllThumbs's Avatar
Re: My Project Boat
1 1/8" spacers hold the two halves apart. I am building a detent system which will detent the rudder in place when down but allow it to swing up in the event of a grounding.
I sail.
post #569 of 577 Old 11-03-2013 Thread Starter
AllThumbs's Avatar
Re: My Project Boat
Trial fit on the boat, plus a picture of the original setup.
I sail.
post #570 of 577 Old 11-03-2013
Re: My Project Boat
Looks really nice and I love the detent system. I know it is a smallish boat but do you think the fiberglass sheet will be strong enough? I am guessing so but I'd probably feel better with aluminum plate, which is what I did when I built a rudder head for my Newport 16.
tschmidty is offline
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 07-19-2016 09:10 PM
help with lifes dream kimby Boat Review and Purchase Forum 37 12-03-2009 12:32 AM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
