Not matching anchor to tackle...? - Page 2 - SailNet Community
post #11 of 18 Old 10-21-2008
jimmalkin's Avatar
I agree with An Lat that a good snubber on chain rode is vital - for numbers of reasons including bending the shaft on the windlass (my PO did so) if the chain runs directly from anchor to windlass. I would encourage line, rather than elastic snubbers, and have had great experience with line called Yale Brait - this from their site Yale Cordage - Ropes for Arborists, Pleasure Marine and Industrial Applications "Originally designed for commercial shipping use, Yale Brait has found a strong following among pleasure marine enthusiasts. Because of its plaited construction, Brait absorbs more energy than other docklines. As a result, hardware on both deck and dock undergo less wear and tear. For added durability and performance, Brait is tuck-spliced by hand to Cordage Institute Standards. Available in White and Black from 3/8" to 5/8".
We use it for chain snubbers and as our secondary rode.
White Rabbit
Vineyard Haven
jimmalkin is offline
post #12 of 18 Old 10-21-2008
never convicted
"....the hauling is done by my wife....." ...an anchor wench?
"Don't gain the world and lose your soul, Wisdom is better than silver and gold"----Bob Marley
100T Master NC
KODAD is offline
post #13 of 18 Old 10-21-2008
You shouldn't be using the windlass as the connection point for the anchor rode. It should be going to a cleat or mooring bitt that is heavily backed and of decent size.
sailingdog is offline
post #14 of 18 Old 10-21-2008
jimmalkin's Avatar
SD - agree absolutely and perhaps I wasn't clear. Our snubber goes from the chain to the heavily backed deck cleat. The PO had used the windlass as the connection point and hence the shaft was bent and we had to replace the whole bloody device. My point about snubbers was a preference for the Brait to rubber devices. Sorry for the confusing post.
White Rabbit
Vineyard Haven
post #15 of 18 Old 10-21-2008 Thread Starter
I'd rather be sailing
labatt's Avatar
This is the snubber we use... works well... http://www.defender.com/product.jsp?path=-1|10391|32295|321087&id=718715
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #16 of 18 Old 10-21-2008 Thread Starter
labatt's Avatar
Yeah... I called her that once, but only once.
labatt is offline
post #17 of 18 Old 10-21-2008
moderate?
camaraderie's Avatar
Originally Posted by sck5 View Post
Sort of on the topic - My new boat is listed at 13000 pounds (dry) and I need to get a new anchor. It seems to me that Deltas get good reviews from everyone who uses them but I am wondering what size to get. We will be sailing up and down the east coast and in the Bahamas. Is the 35lb. model overkill or can I get away with the 22lb?
(and I am imagining I want 5/16 with either)
SCK...no way you should get anything less than 35lb Delta as your primary. Suggest at least 100 ft. of chain for Bahamas coral chafe protection if you are doing a combo rode. I assume you know about the newer designs (Rocna,Spade, Manson et. al.) and have rejected them. A 35lb. Manson would run about $150 bucks more and be superior in my judgement but I lived happily on my delta while cruising so get what your budget allows but get ENOUGH anchor. Not a place you want to skimp.
camaraderie is offline
post #18 of 18 Old 10-21-2008
That wasn't specifically directed at you...since I figured you learned from the PO's mistake.... but as a general statement about anchor rodes. So many people think that a windlass is a good way to secure the rode.
Proper ground tackle for long island sound and new england jasonr575 Cruising & Liveaboard Forum 66 07-15-2007 01:05 AM
New Ground Tackle Setup sailingdog Gear & Maintenance 9 04-30-2007 07:19 PM
Block and tackle design goose327 Gear & Maintenance 42 04-13-2007 12:37 PM
Fishing Under Sail Don Casey Her Sailnet Articles 0 04-18-2002 09:00 PM
Setting Up Reefing Tackle Dan Dickison Learning to Sail Articles 0 12-13-2000 08:00 PM
