Old 10-20-2008
ArgleBargle is on a distinguished road
Continuous Hot Water Heater
Hi
Longshot, i am sure, but has anyone installed/used a continuous diesel hot water heater and have any comments regarding it?
the one I was looking at as a replacemet for an isotherm was the ITR "WaterHeater" that quotes 5.4 A of 12 V current draw, 0.34 Ga diesel/min for 64 deg/52 deg temp rise at 1/1.5 gpm. also has electric element for shore power.
any help appreciated.
cheers
Old 10-20-2008
PS: I have identified & reviewed the prior posts largely regarding non marine and/or propane powered tankless heaters. looking for any one with personal experience with diesel powered continuous/tankless heaters.
thanks!
Old 10-20-2008
JohnRPollard's Avatar
Moderator
Originally Posted by ArgleBargle View Post
... the ITR "WaterHeater" that quotes 5.4 A of 12 V current draw, 0.34 Ga diesel/min for 64 deg/52 deg temp rise at 1/1.5 gpm...
That seems like pretty high fuel consumption -- 0.34 gal/min. Is that figure correct? Or am I misinterpreting it?
Old 10-20-2008
sorry, yes, that should be gallons per hour obviously. typos r us. also , should read deg F
Old 10-20-2008
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
in 1983 on the sheila yeates ( 50 ft on deck topsail ketch ) we wanted a shower we could use in the cockpit that would not use up our fresh water. i took a cummins diesel oil cooler steam cleaned it & made plates for each end that i could hook hoses to. it already had connections in the sides. i put a tee with a ball valve on the side & installed this in the line between the water cooled exhaust manifold & the muffler so i could divert half of the water to the tubes in the oil cooler. the water went through the tubes & out a hose to the cockpit via the bilges & cockpit locker. i connected a hose to the engine side of the thermostat housing through a ball valve to a hose to the side connection on the oil cooler
Old 10-20-2008
captbillc's Avatar
ancient mariner
hot water
i was not done typing my post when it was posted. the water entered the side of the oil cooler over the outside of the tubes & out the other side. another hose connected it to another ball valve that was connected to the other side of the thermostat. to get warm water to the cockpit i opened the 2 ball valves at the thermostat & the ball valve at the exhaust manifold. the hot antifreeze from the engine heated the sea water flowing through the tubes to the hose to the cockpit . we had an unlimited amount of water to shower. we laid a big tarp down in the big cockpit and had a hot tub !
Old 10-21-2008
SteveInMD is on a distinguished road
What the power draw on shore power? Continuous heaters can draw a lot of amps. Make sure your shore power system can handle that plus other loads you may have.
What's your biggest bonehead move sailing? CharlieCobra Seamanship 421 09-26-2011 10:05 AM
Water Heater heat exchanger hook up question EO32 Gear & Maintenance 36 08-25-2008 09:06 AM
Potable Water tdw Provisioning 31 08-11-2007 07:30 AM
Water tanks and a hot day, be aware!!! cjmcfall General Discussion (sailing related) 6 08-06-2007 02:37 PM
Hot Water Heater Replacement sailthechesapke Gear & Maintenance 1 03-27-2001 10:27 AM
