-   -   Shore power problem! Burned ground wire at main breaker (http://www.sailnet.com/forums/gear-maintenance/4820-shore-power-problem-burned-ground-wire-main-breaker.html)
JohnDrake 08-19-2002 07:21 AM
Hi Everyone,
I would appreciate some comments and advice. This past weekend I found that the main breaker kept clipping off when I hooked up shore power. Tested the dockside outlet, cable and receptacle onboard. All good. Got down to the main breaker and found that the black ground wire was burned a bit.
I of course will be calling a yacht electrician, but would appreciate any comments so that I could be better educated about what to do. I am supposing that this could have been caused by a voltage spike from shore power and just replacing the wire and box will be fine. BUT, I am concerned that there could be a fault within the boat and how to ascertain this.
The boat is a 1985 Wauquiez Hood 38 Mark II. Got it in March. No problems until now.
My best to all and thank you in advance.
John
S/V Invictus
lying Deale MD
hunyblond 08-19-2002 02:21 PM
Hi...is this John who is docked next to Neshuma at Herrington North? Just saying hello....this is Sonny''s sailing friend. Hope you get your electrical problem straight. Marlene
JohnDrake 08-20-2002 06:08 AM
Yes! Hi Marlene. Thanks for the note, great screen name. Stop by sometime and I will show you and Sonny the boat.
Still researching the electrical problem, but since DC power is unaffected...I will be sailing this weekend :)
J
