10-22-2008
Marine: Educator,Surveyor
Battery Management:call the manufacturer.
Originally Posted by drynoc
I'm coming back to my roots to get a battery management question answered. I tried on a power boat forum, but that answers have been slow coming. I know someone here will know the answer.
My new boat has two engines and two batteries, but only one battery switch. The owner's manual says never to operate it with the switch in the "both" position. The question then is, how do you operate it? And what is the purpose of the switch if each engine has its own battery? That set up is similar to a car, where the engine takes care of its own battery. I can see the need for a switch that would switch batteries between engines, but this is a standard "off-1-both-2" switch. I can see some utility for the switch in the use of the DC accessories, but not with regard to starting and operating the engines.
Thanks for the help.
Drynoc,
I am assuming the vessel you are asking about is the 1999 Formula 330 SS listed in your previous posts. (nice boat by the way!) On your behalf I put a call into Formula. You should call 260-724-1412 tech help…..Speak to John in tech support and he should be able to answer your question plus provide you with any needed documentation. In the past I have found this company to be most helpful.
Jhj
If the vessel in question is not the one I posted.. list it here or PM me and I will see what we can do.
Additonal to folks.... when you ask a question about a boat, please tell what kind.....even if you have gone over to the dark side.
