10-23-2008
I'd be pretty leery of using twingers in place of a proper downhaul/foreguy on the pole. I can see that it would work, but as mentioned above it's another line that would need to be tended religiously otherwise you've got trouble. A downhaul is to a degree self-tending. (esp if, as on our boats, its NEVER left uncleated.)
We've used twingers on various boats, on the sheet and the guy. On the guy it provides the downward pull mentioned above, stabilizing the pole but also on reaching legs gets the guy down on the deck up to the twinger so that you're not pushing on the lifelines/stanchions with the loaded guy (except at the base).
As the wind pipes up the we also started pulling the twinger on the sheet.. it effectively changes your sheeting angle and again stabilizes the sail and limits its tendency to oscillate and misbehave. In the heaviest conditions downwind we sometimes had the twing on hard both sheet and guy, making it much easier to keep the sail up and not have it dance around - easing loads on the helm as well.
Keep in mind that the twingers are another "chore" that must be tended to properly, and that your crew needs to get them into the routine to make effective use of them.
1984 Fast/Nicholson 345
