Barber haulers, rigging question - SailNet Community
Blogs
Old 10-22-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I can't seem to figure out how to rig barber haulers with one continuous line. Anyone have any suggestions?
Merit 25 # 764 "Audrey"
Old 10-22-2008
mikehoyt's Avatar
mikehoyt is on a distinguished road
Can you further explain what you mean by this?
In my limited experience barbeerhaulers have a seperate line on port and on starbord
Mike
Old 10-22-2008
Difficult to do this with a single line, as the whole affair must be tacked.. since most headsail clews are a least a little behind the mast, it's tough to get a central attachment point for the barberhaul that works.. It would have to be at the front of the mast - giving it a forward component to its pull in most cases. With a non overlapping jib you might get away with it, but not on anything larger.
1984 Fast/Nicholson 345
Old 10-22-2008
zz4gta's Avatar
oh, so I'd need tackle for both port and starboard. Bummer.
If given the choice, would you do the barber haulers (upwind) or look into rigging twings (downwind)? Which seems to have the most benefit? Or is it boat dependant?
Old 10-22-2008
If you're trying to optimize your trim all around the race course you may need to do both. Barber haulers are relatively rare these days; if the genoa tracks are properly placed then they really aren't necessary. OTOH twingers on your spinnaker sheets/guys can make the difference between a broach free run or a crash, esp in a stronger breeze. Proper use of twingers can really stabilize a chute when things start to get exciting. I'll elaborate on that if you need it...
Old 10-22-2008
SteveInMD is on a distinguished road
I agree, you should only need them for close reaching. In this case just put a snatch block on the rail and use and extra line.
Old 10-22-2008
Good point... close reaching legs tend to be longer, and the payoff will make the "hassle" of setting up and removing the barberhaul worthwhile..
Old 10-23-2008
zz4gta's Avatar
My clew is already inside the rail, so I guess they wouldn't do much on my boat.
I'd be interested in more information on twingers. As I understand, they're only "on" the guy, and are a better way to close the luff of the spin? Currently I have a down pole control line going to the midpoint of the spin pole, is this not as desirable? Another Merit 25 I race on doesn't have a down pole, just the twingers.
Old 10-23-2008
tommays's Avatar
tommays is on a distinguished road
The standard J24 has a port and starboard twing and a LOT of people don't use the downhaul anymore BUT if somebody messes up on twings when jibing you can get a really high pole in heavy air
On the 35' boat i race on it has sloted toe rail that allows a snach block to be placed in the ideal position to get the correct sheeting angle when reaching with a jib
For the most part we are trying to get the block forward enough to pull down the upper part of the jib so it is pulling well
It gets more use when we race JAM rather than spinaker becasue we have a starcut reacher chute
There are also angles of sail on the large and small boats that work out well when using a spinaker or wisker pole to help the jib sheeting angle
It takes a huge amount of time and a good notebook to find the best thing to do in a given condition as even a few knots of wind speed will change the best (fast) trim
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-23-2008
Gary3675 is on a distinguished road
I think 505s use a continuous twings...
Standing rigging question brak Gear & Maintenance 25 05-19-2008 10:55 AM
Help with a rigging question please bristol321 Gear & Maintenance 20 06-20-2007 07:31 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 09:00 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 08:00 PM
Another rigging question sailorman_10 Gear & Maintenance 3 05-21-2002 09:40 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
