Old 10-22-2008
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
retabbing bulkheads while on the hard
I am thinking it's a bad idea. My boat needs some tabbing fixed but it seems to me that a trailer puts goofy stresses on the hull that will change once the boat is splashed in the spring.
What are your thoughts on this?
Eric
Old 10-22-2008
It would help if you said what boat it was... but yes, re-tabbing a bulkhead while the boat is on the hard can be a bad idea, since most hulls will change shape slightly when in the water. This is particularly true if the bulkhead in question is a structurally important one. If you do have to do this with the boat out of the water, try and minimize the stress on the hull in the area of the bulkhead you are working on.
Hard dodger GoodOldBoat Gear and Maintenance Articles 8 04-03-2010 09:48 PM
Hull Hard Spot leading to Interior Refit Blueskyzephyr Sailboat Design and Construction 9 01-16-2008 04:44 PM
Cruising with a Hard Dingy on Davits LWinters Cruising & Liveaboard Forum 6 12-27-2006 08:32 PM
On the Hard Far from Home Doreen Gounard Gear and Maintenance Articles 0 08-19-2004 08:00 PM
On the Hard Far from Home Doreen Gounard Cruising Articles 0 08-19-2004 08:00 PM
