Old 10-23-2008
dsbentley's Avatar
dsbentley is on a distinguished road
Send a message via AIM to dsbentley Send a message via MSN to dsbentley Send a message via Yahoo to dsbentley
Stinking heads, anyway to prevent this
Hello from St Croix, Hurricane Omar did quite a number on the boats down here, over 40 boats sunk or destroyed! The Parrothead survived w/o a scratch thanks to the great marina she is located in!fficeffice" />>>
Onto my problem. I have two heads with Skipper toliets that work great. They use seawater to flush and I can either go direct to the ocean when off shore or through my Raritan treatment boxes. The slip I am moored to is at the end of the marina and there is no outlet or circulation of the seawater so I am told the water I am using to flush the heads with is very smelly to begin with and when I flush the heads at the dock I get a very bad odor. I was told I could take a gallon of vinegar and flush with that to help kill the smell. I was also told I could switch on of the heads to a fresh water flushing Raritan head and that would never smell but would use my onboard fresh water to flush.>>
Any comments on this!>>
Thanks>>
Old 10-23-2008
SailorByFate is on a distinguished road
The short answer: buy this book:
Peggy Hall: Get Rid of Boat Odors
It was incredibly helpful to me.
Old 10-23-2008
jjablonowski's Avatar
jjablonowski is on a distinguished road
Fresh water source
It sounds like a fresh-water flush would work.
Before you install any plumbing, check your present hoses. On my boat, the sink drain and the head intake share the same through-hull, with a T connection. For an (occasional) fresh-water flush, I simply close the through-hull and fill the (higher) sink basin with fresh water. Then I suck it into the head.
Old 10-23-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
ever try those big breath mints.
Old 10-23-2008
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
The pump on a manual head usually has a plunger that serves double duty - one side evacuates the waste, the other side draws in the flush water. It is inadvisable to connect a pump like that to a potable water system.
Damn electric heads...fixed them once and for all Giulietta Gear & Maintenance 40 05-12-2008 12:12 AM
Heads Up Houston Insails General Discussion (sailing related) 4 09-13-2007 11:44 AM
Rescued sailor heads home - Daily Pilot NewsReader News Feeds 0 01-08-2007 04:15 PM
Canadian destroyer rescues 3 sailors in storm; heads for another ... - Canada.com NewsReader News Feeds 0 11-09-2006 08:15 PM
Sailing Heads to Nationals (The Harvard Crimson) NewsReader News Feeds 0 04-25-2006 04:15 AM
