10-23-2008
For the most part - if your engine instrument's "plate" is not cracked and allowing a massive amount of water in - most of it will drain and just seep through. As long as the engine is running and any salt deposits etc do not really accumulate (we are talking lots of time here) - you'll be fine.
On my Barberis - the Yanmar engine instruments , ignition, etc are located in the cockpit and currently the plastic housing is cracked severely where the engine cut-off is. That does pose a problem but luckily if that much water gets in it drains down below. So, your only preventive measure is make sure that that particular housing is not cracked - or move them to higher point in the boat (on my C-27 I moved them from the cockpit to the saloon / exterior coaming (forget the technical word for that)...
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
