10-24-2008
SVDS-
I don't know if a pelican case can hold 110 lbs of pressure, which is what propane will create if it leaks. Also, propane may or may not attack the rubber in the o-ring seal on the Pelican case. In either case, you'd want the locker to drain overboard, lest it become a bomb attached to the aft end of your boat.
