10-24-2008
1997 Beneteau 50 cutless bearing
I'm assisting a friend with a problem, the cutless bearing on his 1997 Moorings 50 has walked out from the hull and rested against the prop - there is no major leaking. It appears as thought the cutless bearing is FRP'ed into the hull - does anyone know the layup for that model concenrning the cutless beaaring / prop thruoghhull?
You can't have the binky
