My first pull out. - Page 2 - SailNet Community
post #11 of 14 Old 10-24-2008
moderate?
camaraderie's Avatar
BTW...you are better doing the cleanup this fall and the paint in the spring, just before you drop her back in. Did you have her hauled for your survey?
If not...I suggest you do the soda blasting routine to:
1. quickly get down to the gel coat to determine whether any blisters are present.
2. If #1 leaves you lucky...give it an epoxy barrier coating to protect it for the future followed by the bottom paint of your choice.
camaraderie is offline
post #12 of 14 Old 10-25-2008
Here's my bottom paint story. Hope it helps.
Bought a boat and didn't know what was on the bottom. I called the Interlux help line and they said to paint the bottom with Primicon because it will stick to anything and then apply bottom paint. I'm glad I didn't. Turned the boat had an old graphite bottom paint (KL990?) that is no longer available. I called Interlux back and told them what was on the bottom, and they still said Primicon would work. When I questioned that they did a little checking and found out that Primicon would not work. My boat is small, so we sanded the whole bottom to the gel coat. I'm really glad that we had to do this because now we know that the bottom of the hull is in good shape. So I would say get the soda blasting done. You'll appreciate the peace of mind.
We used the Awlgrip epoxy barrier coat followed by Pettit Horizons ablative bottom paint (in the states you can obviously use Awlgrip bottom paint, but its not licensed in Canada). Expensive, but really easy to work with. The key to the whole thing was getting a good bond between the barrier coat and the bottom paint. The first coat of bottom paint had to go on while the barrier coat was still tacky. Otherwise, we were told the bottom paint would not adhere. We were told that the perfect time to apply bottom paint was when we could leave a fingerprint in the barrier coat but no paint came off on said finger. For us on the the given day with the given weather painting in the shade, this was about 45 minutes.
farmboy
Shark24 #337
farmboy is offline
post #13 of 14 Old 10-25-2008
Farmboy-
Bottom paint will adhere to a barrier coating, even if the barrier coating has dried completely. However, if the barrier coating has dried completely, you do need to sand it very lightly to give it a bit of tooth for the paint to hold onto. By painting the bottom paint onto it when it is still a bit soft, you are just avoiding the need to sand it one more time.
sailingdog is offline
post #14 of 14 Old 10-25-2008
Good to know. Thanks, Dog.
farmboy
Shark24 #337
farmboy is offline
Storm watch… when to pull boat? talismansigns General Discussion (sailing related) 14 09-04-2008 08:00 PM
Harder to pull than expected davidpm General Discussion (sailing related) 8 07-01-2008 10:45 AM
Owners pull boats from shrinking lake - Sacramento Bee NewsReader News Feeds 0 07-29-2007 04:16 AM
Pull the mast or not sailnaway Gear & Maintenance 6 01-15-2005 03:25 AM
