10-24-2008
Please be very careful !!!
Please, please, please be very careful!!!!
Some words of caution:
#1 If your bucket is located higher than your engines siphon-break, NEVER, DON'T & DO NOT shut the engine off without pulling the intake/sea strainer hose from the bucket and letting it suck dry or down bellow the level of the siphon break!!
I always pull the hose and let the impeller suck the remaining water from the hose before shutting down the engine.
Why?
If your bucket is above the engines siphon break your engine can, and will, fill with water and you will hydro-lock it. This is NOT good and will require many, many oil changes to get rid of all the water in the engine. It may not happen the first time but it will and can eventually happen.
Please do yourself a favor and remove the hose from the bucket before you shut down!!! Raw water pumps are NOT valves, are NOT a positive shut off and they do not stop gravity or siphoning. If your bucket is above the engines siphon break it will siphon and you can and will eventually have a hydro-lock situation where your cylinders fill with water.
If you do this in the cockpit, as most of us do, there is a very high likely hood that your engines siphon break is bellow the siphoning level of the bucket.. Pleas be careful.
#2 Never, ever connect a hose straight to your engine. The street pressure will not only blow out the seals of the water pump but within in seconds, even running, it can hydro-lock an engine. Municipal water supplies can have street pressures as high as 100 psi. Use an in/out bucket to avoid serious damage!
In/Out Bucket (Mini Simulated Ocean):
Hose from In/Out Bucket To Sea Strainer:
This is an engine siphon break. If your in/out bucket is higher than the siphon break it can not break or stop the siphoning!!!! Pull the hose before shut down!!!
______
-Maine Sail / CS-36T
