Old 10-26-2008
bristol321 is on a distinguished road
Quiet wind generator?
Next upgrade is the wind generator.....have seen several...but want real opinions....which generator is the quietest?
Old 10-26-2008
Bristol-
Do you want to use the generator to provide a fair amount of power?? If so, then you're probably going to have to get one of the larger, noisier models...since the quiet five-or-six blade models really don't provide much power. They're more a maintenance level charger rather than good for recharging the batteries while in use.
Old 10-26-2008
bobmcgov's Avatar
baDumbumbum
bobmcgov will become famous soon enough
The chief indicators of noise are blade speed and furling mechanism. Turbines with high tip-speed ratios (>5 or 6) are loud due to tip spillage and turbulence. Many small, light turbines (like the SWWP Air models, TSR=9) use slender, high-speed blades to compensate for their minimal electrics -- the "small alternator spun fast" design school. There's all kinds of problems that go with that. Sure, they spool up to charging voltage quickly, but the coils saturate at low wind speeds, they quickly outrun their magnetic flux, output flattens, and then it's just noise noise noise until something flies apart, which doesn't take long usually.
To protect gracile coils from sustained high winds, many small turbines employ some kind of furling or overspeed protection. The five most common methods are:
The Fly Ball (pioneered by Jacobs and most common in larger turbines), in which governing weights slide out from the hub and increase angular momentum; I THINK the KISS units employ something like, Cam will have to comment on that. This method is quiet but has limited governing range.
Blade pitching, where the attack angle is reduced until the blades 'luff' and depower. This is absolutely the BEST means for preventing overspeed and for keeping a turbine generating at peak regardless of wind speed. Alas, it's hard to fit the mechanism into the hub of a small turbine. I don't know of any marine turbine that uses variable blade pitch, but maybe one exists. It is quiet.
Aeroelastic blades: Do Not Go There. In which the turbine governs speed by allowing its blades to flex and spill wind. Good on paper; in reality, the vibrations and flutter set up by independently actuating blades is hell on roller skates. Early SWWP Air models used aeroelastic, and they were terribly noisy. Proven Wind Turbines are downwind models that use an 'oragami' hinged blade that furls the blades conically; clever theory, subject to stresses, don't think there's a boat-sized model.
Side furling: Turbine's yaw shaft is offset from the centerline and the tail is on a sloped hinge, so at a set windspeed the blade plane turns sideways to the wind. This is an elegant and dependable method of overspeed protection. It can also be fairly loud, since you have some blades going upwind and others downwind. The differential loading is also hard on bearings and blade roots. My Bergey works this way, but it's on the hard; I suspect a folding armature might cause trouble in a rolling sailboat.
Finally, there's alternator braking. The leads are shorted together, often many times a second, placing maximum drag on the magnet rotor. Sounds like a fabulous idea, and many small turbines use it. Problem is, a small turbine at governing speeds already has its coils close to saturated. Sustained high winds may cause the blades to 'break away', overcoming the breaking force. Then it's mayhem. Stators melt, rectifiers catch fire, wires burn off, and the blades can accelerate to open-circuit levels. That's REALLY noisy! I can always tell if my turbine has kicked its circuit breaker because it is incredibly loud. Even when its functioning properly, the pulse-loading of an alternator brake can make a queer growling or strobing sound.
The engineering binds inherent in wind turbines are brutal; those inherent in small wind turbines are insuperable. They capture little wind to start, and to get any useful amperage out of them, they require high rotational speeds; to keep them light, they use small electrics and run at the edge of melting. Noise is almost inescapable, given those realities. I'd look for a low-speed unit with a tip speed ratio under six, big rare-earth magnets and coils, good MPPT circuitry to boost charging voltage, and a governing system you can live with. If you want silence, PV is the way to go.
Buccaneer18, Grainnia
SJ21, Diarmuid
Old 10-26-2008
RandyonR3's Avatar
Cruising
RandyonR3 is on a distinguished road
speaking from EXPERANCE, we've had a couple different units over the past number of years, and our concern was not as much noise as it was the powere output and the reliability of the unit.
Our choice was a 4-winds (the older unit with the brushes) as its simple, works well, easy to maintain, and puts out the amps..
After awhile, the little noise, becomes unheard and one thing to remember, thats the sound of money.
Old 10-26-2008
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
The quietest are useless, very little output. If you're on a mooring and only interested in a trickle charge for your batteries they'd be ok but if you're going to cruise and run a fridge I'd suggest a KISS. They all make a bit of noise but it's a comforting sound and at night it will tell you when you need to get up and have a look around. Just don't get an Airmarine or AirX or whatever, nobody will let you anchor near them.
Rick I
Toronto in summer, Bahamas in winter.
Old 10-26-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
I have never owned a wind generator, but during the many, many thousands of hours I have spent on the docks, I have frequently noticed that Rutland generators were always extremely quiet. Noticably more so than any others I have ever been around.
"Clean bottoms are FastBottoms"
Old 10-26-2008
Vasco's Avatar
Warm Weather Sailor
Rutlands and Aerogens are very quiet but negligible output.
Rick I
Old 10-26-2008
badsanta is on a distinguished road
Originally Posted by bobmcgov View Post
I'd look for a low-speed unit with a tip speed ratio under six, big rare-earth magnets and coils, good MPPT circuitry to boost charging voltage, and a governing system you can live with. .
Thanks for some very good insight. Given your parameters, what would you suggest I look at? Many thanks
Old 10-26-2008
camaraderie's Avatar
moderate?
Four Winds or Kiss. Everything else gives you roughly 1/2 the output in 10 knot winds which is what the majority of your charging will be done at in anchorages. That is the difference between 100ah's a day vs. 50!! Both the KISS and the fourwinds have fairly low noise associated with them. We lived nicely with a fourwinds for several years and came to welcome the hum!
Before you decide ANYTHING...go to the various mfr. sites and find the amperage on their output curves at 10 knots multiply that by 24 hours and then decide what you want for your $$.
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 07:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 08:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 07:00 PM
