Ditch the Hot Water Tank? - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 10-27-2008
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
Our water heater had the same symptoms as yours, so we installed the Isotherm unit 6 years ago. Connecting it to the engine is easy. We've never connected it to shore power. As mentioned above, limited motoring to an anchorage in the evening warms up the water enough to make it useful for a shower the next morning. The insulation matters. Even 12 hours later, I have to mix in warm water or it's too hot. While I can use marina facilities to shower, I prefer doing so before I leave the boat.
IRMV
  #12 (permalink)
Old 10-27-2008
JSL3's Avatar
<----- thinking of this
JSL3 is on a distinguished road
Originally Posted by ahalfon View Post
The hot water tank in my Pearson 28 (2) is pretty rusty and has seen better days. I've had the boat for about two years now and haven't really used it since the heater only works when connected to shore power, which usually means there are marina facilities to be had.
I have the same boat, 1986 P28-2. For what it's worth, my tank is hooked up to the engine and provides blistering hot water after a short run of the engine. The tank is also is a bit rusty (the water isn't) but still functions quite well.
In my opinion, hot water is one of the features that made this boat more attractive to me and I consider it a great feature. As suggested earlier, I'd consider the effect on resale if you remove it. Your call obviously.
Good luck.
~Jim
Ramble On
1986 Pearson 28-2
  #13 (permalink)
Old 10-27-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
Hot water is a nice thing to have especially if you ever plan to have guests on board.
  #14 (permalink)
Old 10-27-2008
Irrationally Exuberant
arf145 is on a distinguished road
I'm with JSL3. I also have a 28-2 and the hot water is connected to the engine. Are you sure yours isn't?--because that would complicate the tank removal a bit.
I like the hot water--like Jim said, we get super hot water after any kind of engine run. We haven't used the hot much yet, but next year we'll do more overnights, and I know it will be welcome.
arf145
1987 Pearson 28-2
Chesapeake Bay
  #15 (permalink)
Old 10-27-2008
johnshasteen's Avatar
johnshasteen is on a distinguished road
I'm currently considering removing the tank to free up some space in the lazarette and reduce winterizing hassle, but wanted to get some opinions first to make sure I'm not making a big mistake by not considering all the consequences.
Also, I'm not exactly sure what this project would entail - especially from an electrical standpoint - and how big of an undertaking it represents...
Thanks,Amir
You didn't say, but you probably have a Raritan 6-gallon 110V electric only. Replace it with a new one with both electric and heat exchanger so you will have hot water wherever you go. The new Raritans have fiberglas shells and glass liners and don't rust out like the old ones.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
  #16 (permalink)
Old 10-27-2008
Especially guests of the female persuasion.
  #17 (permalink)
Old 10-27-2008
captw3 is on a distinguished road
A side function of the water heater in the cooling loop is it is an additional heat sink for the diesel, and resale is always better with the option.
Rick
  #18 (permalink)
Old 10-27-2008
ahalfon is on a distinguished road
Thanks for all the detailed responses! I'm pretty much convinced that the resale value justifies fixing the situation rather than ditching the tank
johnshasteen/jsl/arf - this is indeed a Raritan 6-gallon electric only, and replacing it with a newer one with a heat exchanger does sound like the best thing to do. Are you referring to the 1700 series? According to their website it's glass-lined steel rather than fiberglass.
More importantly though, how big of an undertaking are we talking about? Is this still within the realm of a DIY project? Any pointers would be greatly appreciated...
Thanks again,
Amir
  #19 (permalink)
Old 10-27-2008
Firstly is your engine fresh water cooled? Engine heated HW is rare with RWC engines.
If it is FWC, then you'd be best to consult with the manufacturer or compare to similar installations as to precisely where to tap into your cooling system for the HW tank. But it's definitely in the DIY realm, simply remove a coolant hose, run it to the tank and back to the other end of the original hose, so that the coolant recirculates through the tank coil as well as cooling the engine.
Getting the connection in the right place is important, you could interfere with the proper circulation of the coolant in the engine if you get it wrong. The manual may show where, or compare to another installation.
The electrical is easy, just reconnect your old tank's wires to the new tank's heating element.
I don't think you'll regret this down the road.....
1984 Fast/Nicholson 345
  #20 (permalink)
Old 10-27-2008
Indeed, it's a fresh water cooled engine - a Yanmar 2GM20F.
JSL3 / arf145: I'm assuming you have the same engine? Any chance you'd be able to post pictures of your hot water tank hookup? -- I'm trying to figure out how to run the hoses to a tank in the lazarette...
Thanks again!
Amir
replacing built in water tank jbrockpiano Gear & Maintenance 6 02-01-2008 04:07 PM
Marine Tankless Water Heaters Granuaile Pacific Seacraft 4 12-18-2007 11:50 PM
Possible Water In Diesel tank sabre28guy Sabre 1 05-18-2007 10:40 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
