Blogs
User Name
Old 10-26-2008
ahalfon ahalfon is offline
ahalfon is on a distinguished road
Ditch the Hot Water Tank?
The hot water tank in my Pearson 28 (2) is pretty rusty and has seen better days. I've had the boat for about two years now and haven't really used it since the heater only works when connected to shore power, which usually means there are marina facilities to be had.
I'm currently considering removing the tank to free up some space in the lazarette and reduce winterizing hassle, but wanted to get some opinions first to make sure I'm not making a big mistake by not considering all the consequences.
Also, I'm not exactly sure what this project would entail - especially from an electrical standpoint - and how big of an undertaking it represents...
Thanks,
Amir
Old 10-26-2008
newpbs newpbs is offline
newpbs is on a distinguished road
Hot Water can be nice
I'm sorry to hear that your present tank goes unused. Perhaps if your tank was hooked up to your engine as mine is you would enjoy it more. In the 12 minutes that I motor out to the open lake and set sail I get nice warm water that I can use for the next few hours. It's nice to wash up with warm water, and I get it by just motoring out to the lake.
The choice is yours and maybe the extra space is of greater value. Will you sell anytime soon? Having hot water could be a selling point.
Maybe if you installed a system that can run off of your engine, like I have, you would use it more.
Good luck.
Old 10-26-2008
PBzeer's Avatar
PBzeer PBzeer is offline
Wandering Aimlessly
PBzeer has a spectacular aura aboutPBzeer has a spectacular aura aboutPBzeer has a spectacular aura about
There should only be one three strand AC wire going into the Hot Water heater. You may also have 2 hoses running off your engine to circulate water to heat the tank, and your inlet and outlet from the freshwater system as well. Other than that, it's just a matter of draining and unscrewing the unit.
If you want the convenience of hot water at the dock, you could get an electric instant hot water unit (last I looked about $225 at West Marine).
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
Music on the Wind -
www.sailaria.net
Sponsored Ad
Old 10-26-2008
Faster Faster is offline
Moderator
Faster has a spectacular aura aboutFaster has a spectacular aura about
If the old tank is rusty and disused, there's no reason not to remove it.. And as PB says electrically it's no big deal.. if your boat's unplugged from shore power when you do it the circuit is sure to be dead. Once disconnected, be sure to disconnect the wires at the breaker too, so that you won't end up with live wires when you're plugged in.
If you find yourself spending more time away from docks and want hot water again, then look into buying a good SS tank and install it into the coolant loop of your engine (if it's FWC) and you'll have the best of both worlds if you reconnect the electric element. It is a big plus for resale.
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
Old 10-26-2008
sww914 sww914 is offline
wannabee
sww914 is on a distinguished road
I had an on-demand propane unit on my big tri, I loved it. It was small & light and not expensive to run. If you don't already have propane on board it would hardly be worth it.
Old 10-27-2008
SVDistantStar's Avatar
SVDistantStar SVDistantStar is offline
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
I ditched my 120v hot water heater awile back when i went out on anchor. IT worked, but gave out rusty looking water.
I want a propane instant unit, but i cant find one anywhere.
1972 Pearson 36 S.V. Distant Star
Old 10-27-2008
wannabee
On demand water heaters on ebay. About $200.00. They look exactly like the one I bought from Defender 10 years ago with a different label. They're not marine grade but they're cheap enough to replace every few years. IIRC I had to plumb a tee on the output for a pressure relief valve, it was $10-$20 at the hardware store.
Old 10-27-2008
Moderator
A major caveat about these "non marine" propane-fired instant heaters.. many insurance companies will not cover them. Check before you buy!
Old 10-27-2008
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Getting a non-marine grade propane appliance for the boat strikes me as a bit foolhardy. The chances of being blown up or poisoned probably go up quite a bit with non-marine appliances, since pinholes from corrosion are probably much more a likelihood.
If you're new to the Sailnet Forums... please read this POST.
Old 10-27-2008
Bene505's Avatar
Bene505 Bene505 is offline
Glad I found Sailnet
Bene505 is on a distinguished road
I'm thinking that angle of heel may also be a factor, since home units are probably designed to be level. There was a thread about non-marine propane 'fridges awhile back, that summed-up as "don't do it".
vB code is On
replacing built in water tank jbrockpiano Gear & Maintenance 6 02-01-2008 04:07 PM
Marine Tankless Water Heaters Granuaile Pacific Seacraft 4 12-18-2007 11:50 PM
Possible Water In Diesel tank sabre28guy Sabre 1 05-18-2007 10:40 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
Page generated in 1.5984 seconds (85.31% PHP - 14.69% MySQL) with 16 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
