Which oil changing pump is best? - Page 3 - SailNet Community
post #21 of 25 Old 08-10-2009
djodenda's Avatar
Originally Posted by midlifesailor View Post
Awesome thanks. I'm not sure if my local WM carries these things as I've never seen one there. I won't need one until time to winterize so I'll check again but if not I likely order from Defender and hope it comes with the fitting I need. If not I'll try to rig something up from the marine section of Home Depot.
You can get the smaller one from WM online. I expect you will come out $ ahead if you don't need the larger one....
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #22 of 25 Old 08-10-2009
Maine Sail's Avatar
Moeller
Moeller hands down. Here's a video I made so you can see how easy it is..
Moeller Fluid Extractor Video (LINK)
______
-Maine Sail / CS-36T
Maine Sail is offline
post #23 of 25 Old 08-10-2009
Special Delivery
speciald's Avatar
Send a message via Skype™ to speciald
I love my Reverso pump. Turn it on, pump out the oil. Change the filter, reverse the pump and refill the engine. Its plumbed to both the main engine ang genset.
speciald is offline
post #24 of 25 Old 08-10-2009
another vote for Moeller
I tried the West Marine version but it is poorly made. I struggled for 30 minutes to get 1 litre (quart to the rest of the world) out and the second time I tried to use it I could not get anything out. I suspect the pump actually broke the first time I used it. It would generate a little vacuum when pumping but would not sustain it when I stopped. I was sufficiently annoyed that I seriously considered chucking it in the dumpster on my way out of the marina. I took it back to West Marine and exchanged it for the Moeller pump. (they stood by their word and accepted it without question - despite it being obviously used) The Moeller pump worked like a charm, 10 strokes and the oil came right out in a few minutes. This unit is very well made, you can see and feel the difference if you handle them both. (I have no vested interest in either Moeller or West Marine.)
KBuckley is offline
post #25 of 25 Old 08-11-2009
djodenda's Avatar
That's nice, but I find the whole toe-wiggling thing a bit disturbing.
David
David
djodenda is offline
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
