Old 10-27-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
I need a new pricker (Force 10 heater)
I fired up my Force 10 fuel-oil heater only to discover the burner clogged. I took the burner apart and found the pricker thing, which is a very tiny little wire on the end of a rack, was bent over and would go into the hole in the burner anymore. Can I get parts for this anymore? Anyone know a good source? It seems like Force 10 has gone through many hands since they produced an oil burning heater, and I haven't ever had luck e-mailing or calling them. Is there someone in specific that works there that understands their old oil burning products? Or am I just screwed??? I would hate to have to spend another $1000 on a new Dickerson and cut a bigger hole into my cabintop all because of a 1/4" long piece of wire
Old 10-27-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
Have you tried sizing wire that should be on the boat to begin with.
Old 10-27-2008
sailboy21's Avatar
Its about the same diameter of a bristle of a brush, but pointed at one end and secured somehow in a little gear rack which itself is about the size of a piece of macaroni... Did you mean "seizing wire"? BTW I took it home to work on
Old 10-27-2008
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
piano wire
piano wire comes in a lot of different diameters and is stiff. i think wire like this would be what you need --- if you can attach it properly.
Old 10-27-2008
capttb is on a distinguished road
Might try calling the folks at attached website, all you really need is a "cleaning needle" which is just a piece of stiff wire w/ handle the right size for your jet.
A & H Enterprises - A & H Enterprises is the only North American service center for Optimus and Svea stoves.
Old 10-27-2008
sailboy21's Avatar
It is built into the valve body on this model... searching all over the internet and it seems a lot of people are looking for parts for these thing on just about every message board and no one reporting any known sources not a good sign..
The pricker:
Old 10-27-2008
Ah, I have an ancient Optimus white gas stove with a similar "internal" cleaner. A&H actually still has parts for it, they claim to have parts or repair Force 10 products also. Probably too much to hope for a replacement from some other brand using the same valve. Good luck, sorry I was no help.
Old 10-28-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Contact Sig Marine - they bought out that line (so I heard so may not be true) and may be able to to get you going...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 10-28-2008
catamount's Avatar
catamount is on a distinguished road
If worst comes to worst, you could try removing the internal pricker and just clean the burner jet as needed manually with an external pricker tool.
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
Old 10-28-2008
timebandit's Avatar
timebandit is on a distinguished road
Welders use a tip cleaner that comes in a set for a coupple of bucks that has a coupple of differdnt sizes.
Rick
Force 10 cozy heater flydude3 Gear & Maintenance 2 01-10-2010 11:11 PM
Force 10 Diesel Cabin Heater KeelHaulin Gear & Maintenance 22 10-14-2009 02:14 PM
winterize hot water heater? saltypat Gear & Maintenance 6 10-26-2007 11:47 AM
Force 10 heater Desmond Gear & Maintenance 2 11-29-2006 12:03 AM
Force 10 Cabin Heater quinlanmw Gear & Maintenance 11 12-27-2003 05:25 PM
